[snappyHexMesh] 6.5 Creedmoor Exterior ballistic Mesh
Old   June 15, 2024, 11:51
Default 6.5 Creedmoor Exterior ballistic Mesh
Annoy Yu
CFD padawan is on a distinguished road
Hello Everyone,
Currently, I'm working on exterior ballistics and have developed access to a 6DOF ballistic calculator. To make the calculator operational, various coefficients at different velocities are required. Presently, I'm endeavoring to create a model to determine these coefficients for the 6.5 Creedmoor. This involves considering a MRF along with projectile geometry. The projectile spins at approximately 242,000 rpm.
Now, to the main issue: I'm utilizing snappyHexMesh for mesh generation, but I'm encountering difficulties achieving a smooth surface over the projectile. Please refer to the attached image illustrating the mesh domain cross-section. As I'm relatively new to Computational Fluid Dynamics (CFD), I appreciate your patience.
Any recommendations for sources (books, websites, etc.) or instructions would be highly valued.
Best regards,
D
P.S. snappyMeshDict is below
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 7
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
castellatedMesh true;
snap true;
addLayers false;
geometry
projectile
type triSurfaceMesh;
file "projectile_m.stl";
inlet
file "inlet_m.stl";
outlet
file "outlet_m.stl";
boundary
file "boundary_m.stl";
//- Used to define MRF zone and to refine mesh round the impeller
MRF
type searchableCylinder;
point1 (.076 0.0 0.0);
point2 (.130 0.0 0.0);
radius .004;
castellatedMeshControls
maxLocalCells 100000;
maxGlobalCells 2000000;
minRefinementCells 0;
nCellsBetweenLevels 2;
maxLoadUnbalance 0.10;
resolveFeatureAngle 1;
planarAngle 1;
features
file "projectile_m.eMesh";
level 7;
file "inlet_m.eMesh";
level 0;
file "outlet_m.eMesh";
level 0;
file "boundary_m.eMesh";
level 0;
refinementSurfaces
MRF
level (1 1);
cellZone cellMRFzone;
faceZone faceMRFzone;
cellZoneInside inside;
projectile
level (5 6);
inlet
level (0 0);
outlet
level (0 0);
boundary
level (0 0);
refinementRegions
MRF
mode inside;
levels ((1E15 4));
locationInMesh (0.080 0.0 0.0); // Inside point
allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
nSmoothPatch 3;
tolerance 1.0;
nSolveIter 300;
nRelaxIter 50;
nFeatureSnapIter 10;
implicitFeatureSnap false;
explicitFeatureSnap true;
multiRegionFeatureSnap false;
// Settings for the layer addition.
addLayersControls
relativeSizes true;
layers
meshQualityControls
#include "meshQualityDict"
// Advanced
//- Number of error distribution iterations
nSmoothScale 4;
//- Amount to scale back displacement at error points
errorReduction 0.75;
writeFlags
mergeTolerance 1E-6;
CFD padawan is offline   Reply With Quote
exterior ballistic, projectile, snappyhexmesh 3d
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[snappyHexMesh] High quality mesh for wind in complex urban environment ziboaa OpenFOAM Meshing & Mesh Conversion 1 January 12, 2021 16:33
[ICEM] Bad Quality Hybrid Mesh External Flow tim13 ANSYS Meshing & Geometry 0 March 8, 2020 03:22
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
