[snappyHexMesh] snappyHexMesh fails but Fluent mesh works ? |
June 13, 2024, 04:35 |
Hello all,
I have a query in snappyHexMesh. When I imported Ansys Fluent mesh into OpenFOAM, gas turbine combustor runs well in a transient state and converges at t= 0.2s with time step of 1e-6. But with snappyHexMesh, the case struggles in a transient state, and at t=0.2s, the flow just gets initiated in the downstream, which is weird. I tried almost all the tricks playing with different parameters but nothing helps. Here is my snappyHexMeshDict and image attached. If someone has gone through the same, kindly share your thoughts please. I need some lead to get going. Thank you |
June 13, 2024, 05:26 |
This is the result of Fluent mesh, captured at t = 0.002s
Whereas in OpenFOAM with same conditions, even when t = 0.006s, the flow doesn't come out from the swirler into the downstream. I checked till t = 0.2s in OpenFOAM. At t = 0.2s, the flow gets initiated in the downstream box but as per the experiment results, the convergence should happen at t = 0.2s. |
June 13, 2024, 05:29 |
So, i couldn't able to understand the bug in the snappyHexMesh.
ansys fluent mesh, snappyhexmesh 3d |
Error: WorkBench Error: Could not handle event: SolutionStatusUpdate | Kieyo | Fluent Multiphase | 0 | November 9, 2022 23:58 |
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? | RPjack | ANSYS Meshing & Geometry | 2 | August 27, 2015 09:33 |
[OpenFOAM] snappyHexMesh - can't open mesh in ParaView | tfigueiro | ParaView | 0 | June 11, 2015 19:05 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
