[blockMesh] Have to chang BC but i already did sHM. |
June 13, 2024, 00:33 |
Kihyun
Good morning (i am in seoul, LoL)
I have simple question. I already finished snappyHexMesh, and it took 40minutes. After that i realized i need to change slip wall condition to patch. If i change BC in blockMeshDict ,0/U, and 0/p... Do i need to do snappyHexMesh again? |
June 13, 2024, 03:04 |
M
Rep Power: 13 |
Better: you can to go the finished mesh in ../polyMesh/ and open the "boundary" file. Just look for your patch and change it from "wall" to "patch".
FYI: if you change in blockMesh, you would have to run the meshing again obviously. The finished mesh does not have any reference to any of the dicts it was build with. It just contains the information that form the mesh itself, e.g. where the points, edges, faces are and how the cells are connected and so on. In 0/U and 0/p you need to specify a BC that is compatible with the patch type you set in polyMesh/boundary. |
[snappyHexMesh] SHM does not snap if I increase cells in blockMesh or increase maxNumbercells in SHM | Aarib | OpenFOAM Meshing & Mesh Conversion | 1 | January 30, 2024 02:28 |
[snappyHexMesh] SHM doesn´t snap reliable to feature edge | OpenFOOL | OpenFOAM Meshing & Mesh Conversion | 5 | January 4, 2023 11:58 |
[snappyHexMesh] No Boundary Layer Created in SHM | GDS | OpenFOAM Meshing & Mesh Conversion | 4 | October 9, 2021 18:49 |
[snappyHexMesh] Advice on limitations of SHM | Tobermory | OpenFOAM Meshing & Mesh Conversion | 0 | February 26, 2021 08:09 |
[snappyHexMesh] troubles with sHM and parallel | Tobi | OpenFOAM Meshing & Mesh Conversion | 1 | August 30, 2012 18:54 |
