[snappyHexMesh] .stl floating object definition
Old   June 9, 2024, 16:32
Default .stl floating object definition
mechanicalhead is on a distinguished road
Hello everyone,
I am new to the field of SHM and OpenFOAM. Currently, I am working on simulating the behavior of a floating body using the waveDyMFoam solver. Initially, I successfully created a mesh using SHM and simulated the motion of a 3D cylinder according to my plan. I achieved this by creating a searchableCylinder in the SHM dictionary.
However, I encountered a challenge when I tried to use the geometry by importing an .stl file of a cylinder through the triSurface feature. Although the mesh created from the .stl file appeared to be correct, the motion of the cylinder was not as expected. Instead of rotating as needed, it only moved in the direction of the waves.
I would appreciate any guidance or suggestions on how to improve the simulation using the .stl geometry. Specifically, I would like to ensure that the cylinder rotates correctly according to my specified initial angle, similar to the behavior achieved with the searchableCylinder. Thank you in advance for your help.
mechanicalhead is offline   Reply With Quote
error in fireFoam, when running the case wallFireSpread2D zhoubiao1088 OpenFOAM Running, Solving & CFD 9 February 1, 2018 19:45
interDyMFoam Floating Object with snappyHexMesh not working ocalloc OpenFOAM Running, Solving & CFD 1 May 27, 2016 10:42
[cfMesh] CFMesh: feature definition or extraction in the .stl file Gio Baila OpenFOAM Community Contributions 11 December 17, 2014 05:28
[OpenFOAM] Floating Object Tutorial. No fluid shown when I click on "Play" Ivy Zhou ParaView 6 October 9, 2013 04:02
