June 1, 2024, 04:39 |
ideasUnvToFoam
Rep Power: 2 |
Hello,everyone.I use ideasUnvToFoam to convert a Unv-Format file into polyMesh.All the four txt-files faces,neighbour,owner and points have nothing but only a bunch of garbled code.I have installed OpenFoam-10 and OpenFoam-11.The result are same and in the picture showed.What is the reason?
June 17, 2024, 07:47 |
Niels Nielsen
Rep Power: 27 |
You have most likely enabled binary mode in controlDict.
writeFormat binary;// or ascii
Linnemann PS. I do not do personal support, so please post in the forums. |
June 18, 2024, 04:02 |
Rep Power: 2 |
I have solved this problem.Thank you for your help!
ideasUnvToFoam error | antoniovalos | Main CFD Forum | 1 | June 1, 2023 11:15 |
[Salome] IdeasUNVToFoam - big meshes | malcolm.akner@hotmail.com | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2021 14:00 |
ideasUnvToFoam ----> failed | Nic86 | OpenFOAM | 1 | February 5, 2020 01:22 |
[Salome] ideasUnvToFoam Error: Assertion `nouveau > -1' failed | GerhardHolzinger | OpenFOAM Meshing & Mesh Conversion | 0 | January 29, 2019 10:23 |
[Salome] ideasUnvToFoam problem with internal groups | s.marcocalero | OpenFOAM Meshing & Mesh Conversion | 0 | May 31, 2013 11:48 |
