[Other] CFMesh: Interrupted Refinement using TetMesh in Elbow Geometry |
May 28, 2024, 04:51 |
Rep Power: 2 |
Hi, all.
I am testing cfMesh as an open source mesher on a mixing elbow. No issues in terms of workflow, the stl file from SALOME have been converted into an .fms file and the simulations are running smoothly. However, when I am using the tetMesh, the object refinement I have placed in the bend of the elbow works well, then stops and then it refines again. Has anyone encountered such an issue? I have attached an image for clarity. I don't encounter this necessarily with cartesianMesh or pMesh. Any suggestions are welcome. This issue increases my mesh skewness a lot. Mesh dict is here: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | cfMesh: A library for mesh generation | | \\ / O peration | | | \\ / A nd | Author: Franjo Juretic | | \\/ M anipulation | E-mail: franjo.juretic@c-fields.com | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object meshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // //By default I think the dimensions are in metres. surfaceFile "elbow_90degree.fms"; maxCellSize 0.02; boundaryCellSize 0.02; keepCellsIntersectingBoundary 1; objectRefinements { elbow_refinement { type sphere; cellSize 0.012; centre (0.04 0 0.04); radius 0.05; refinementThickness 0.1; } } boundaryLayers { nLayers 5; thicknessRatio 1.2; maxFirstLayerThickness 0.0015; allowDiscontinuity 0; } renameBoundary { defaultName walls; defaultType patch; newPatchNames { inlet1 { newName inlet1; type patch; } outlet { newName outlet; type patch; } symmetry_plane { newName symmetry_plane; type symmetry; } walls { newName walls; type wall; } inlet2 { newName inlet2; type patch; } } } // ************************************************************************* // |
cfmesh, refinement, tetmesh |
[Other] dynamic mesh not showing in paraview | joshmccraney | OpenFOAM Meshing & Mesh Conversion | 7 | April 12, 2023 11:38 |
problem with parallel calculations OF8 mpirun | otaolafr | OpenFOAM Programming & Development | 0 | January 5, 2021 07:33 |
[snappyHexMesh] Not Able to Refine Mesh in Refinement Box | noodleluvmay | OpenFOAM Meshing & Mesh Conversion | 2 | January 27, 2020 10:55 |
[Other] Multilevels Refinement with cfMesh | RemyCavecchia | OpenFOAM Meshing & Mesh Conversion | 2 | September 18, 2018 17:08 |
[snappyHexMesh] FOAM Warnings leading to no geometry, yet OpenFOAM says meshing finished w/o error | edomalley1 | OpenFOAM Meshing & Mesh Conversion | 1 | September 5, 2018 18:30 |
