May 22, 2024, 21:53 |
blockMesh of expansion cylinder
Sebastián
Hi! I am trying to create a blockMesh of a expansion cylinder. It seems to have some problems, when I run "checkMesh" it says it has failed 5 mesh checks, so there must be something wrong. I leave the blockMeshDict, a picture of the vertices so it is easier to follow the dictionary and a picture of the geometry it creates, which seems to be okay but there must be something wrong because I have problems when running foamRun. Thanks
May 23, 2024, 02:22 |
Mark Olesen
Rep Power: 40 |
A good place to start is with "blockMesh -write-vtk". This will generate VTK files corresponding to your block structure, which you can then explore in paraview to verify that your blocks are actually what you thought you wanted.
As mentioned in https://develop.openfoam.com/Develop...raview-plugins the "hover points on" function is really useful. |
[blockMesh] Hole in a cylinder / T-junction of two cylinders using blockMesh | anuragm | OpenFOAM Meshing & Mesh Conversion | 4 | March 2, 2018 08:36 |
[blockMesh] How to create a T-junction cylinder with blockMesh | Blanca | OpenFOAM Meshing & Mesh Conversion | 1 | February 24, 2018 06:24 |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 06:24 |
[blockMesh] Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 03:56 |
