[snappyHexMesh] refine only one dirextion
Old   May 22, 2024, 08:38
Default refine only one dirextion
Huang, Ching-Chan
Allen_Huang is on a distinguished road
Is anyone know how to correctly refine with x or y direction, rather than z direction, I have try levelIncrement, but it still have z direction cell to refine. I dont want to use extrudeMesh.
Here is my snappyHexMeesh code:
FoamFile
format ascii;
class dictionary;
object snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap true;
addLayers true;
geometry
"airfoil.stl"
type triSurfaceMesh;
name wing;
cylinder1
type searchableCylinder;
point1 (0.025 0 0);
point2 (0.025 0 0.001);
radius 0.1;
cylinder2
point1 (0 0 0);
point2 (0 0 0.001);
radius 0.3;
cylinder3
point1 (0 0 0);
point2 (0 0 0.001);
radius 0.4;
castellatedMeshControls
maxLocalCells 10000000;
maxGlobalCells 200000000;
minRefinementCells 100;
nCellsBetweenLevels 50;
features (
refinementSurfaces
wing
// Surface-wise min and max refinement level
level (3 3);
levelIncrement (3 3 (3 3 0));
resolveFeatureAngle 30;
refinementRegions
cylinder1
mode inside;
levels ((1.0 2));
levelIncrement (2 2 (3 3 0));
gapLevel (5 0 10);
gapMode inside;
cylinder2
mode inside;
levels ((1.0 1));
levelIncrement (1 1 (2 2 0));
cylinder3
mode inside;
levels ((1.0 0));
levelIncrement (0 0 (2 2 0));
locationInMesh (-0.5 0 0);
allowFreeStandingZoneFaces true;
snapControls
nSmoothPatch 5;
tolerance 3.0;
nSolveIter 30;
nRelaxIter 8;
nSmoothIntrnal 5;
addLayersControls
relativeSizes true;
layers
wing
nSurfaceLayers 10;
expansionRatio 1.3;
finalLayerThickness 1;
minThickness 2;
nGrow 0;
featureAngle 60;
nRelaxIter 5;
nSmoothSurfaceNormals 1;
nSmoothNormals 3;
nSmoothThickness 10;
maxFaceThicknessRatio 0.5;
// Reduce layer growth where ratio thickness to medial
// distance is large
maxThicknessToMedialRatio 0.3;
minMedialAxisAngle 90;
nBufferCellsNoExtrude 0;
nLayerIter 50;
meshQualityControls
//- Maximum non-orthogonality allowed. Set to 180 to disable.
maxNonOrtho 65;
maxBoundarySkewness 20;
maxInternalSkewness 4;
maxConcave 80;
minVol 1e-13;
minTetQuality 1e-30;
minArea -1;
minTwist 0.05;
minDeterminant 0.001;
minFaceWeight 0.05;
minVolRatio 0.01;
minTriangleTwist -1;
nSmoothScale 4;
errorReduction 0.75;
mergeTolerance 1e-6;
Allen_Huang is offline   Reply With Quote
Old   May 23, 2024, 03:29
Will Kernkamp
wkernkamp is on a distinguished road
You can make cells smaller in z direction in blockMesh. That should also make them smaller in snappy in z direction.
wkernkamp is offline   Reply With Quote
Old   May 23, 2024, 07:33
M
AtoHM is on a distinguished road
You can use directional refinement in snappyHexMesh; only in the ESI distribution, though.
Then I think you have some errors. When using directional refinement, you must basically disable the "level" by using something like
levels ((1E30 0))
And then after that, you specify levelIncrement in the way you did, but re-check what the parameters mean. The definition you have here
does the following: it takes cells of level min (2) to max (2) and applies 3 splits in x, 3 splits in y and 0 splits in z. This is probably not what you want. Snappy does not expect the target level here in the second bracket, but the amount of splits.
What you want is probably something like
levelIncrement (2 2 (1 1 0));
which gives you these level 2 cells split to 3 3 2.
For directional refinement, the thing you get is always relative to the level you had on this position before. If your refinement includes a near wall region where you have 1 on the wall and then you use (2 2 (1 1 0)), nothing will happen. To get this level 1 also to 3 3 2, you have to add another refinement with the setting (1 1 (2 2 1)).
If you include more levels in the selection min/max, e.g. (1 2 (2 2 1)), the cells of level 1 get split to 3 3 2 and the ones of level 2 get split to 4 4 3. You see, that if your refinement region contains different cell sizes, you cannot bring them all to the same levels with just one definition, you need to handle them separately.
Hope this helps to understand the parameters.
P.S. I have never used directional refinement for surfaces, I doubt it works at all, or if it does, it probably gives you quite bad cell quality.
AtoHM is offline   Reply With Quote
extrudemesh, refine, snappyhexmesh, snappyhexmesh 2d
[Other] Refine near wall layers zxj160 OpenFOAM Meshing & Mesh Conversion 2 August 25, 2022 08:57
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
How to refine the mesh only on a specific region on a part mazhar16823 Main CFD Forum 0 June 22, 2020 07:49
[snappyHexMesh] SHM refine domain wall Tomatenbart OpenFOAM Meshing & Mesh Conversion 0 July 10, 2017 11:54
Overset: refine background mesh without resetting the mesh JohnAB STAR-CCM+ 6 May 19, 2014 14:48
