[snappyHexMesh] SnappyHexMesh not snapping around stl/not working
Old   May 10, 2024, 04:19
Default SnappyHexMesh not snapping around stl/not working
Charly23 is on a distinguished road
Hi everybody
I have already used snappyHexMesh successfully but now I am facing a problem. It is running but the result is the same as the previous blockMesh, sHM is not snapping around my stl file at all. I tried my sHM with another a bit smaller stl geometry and there it is working properly. Does somebody have an idea why it is not working?
I also already created a new stl of my geometry but still no change.
I attached my stl, blockMeshDict and snappyHexMeshDict.
Thank you so much in advance
Charly23 is offline   Reply With Quote
Old   May 10, 2024, 17:57
Will Kernkamp
wkernkamp is on a distinguished road
I did not see a problem generating the mesh with your input Dicts. However, you provided stl file ImportOFkl_3Dchannel_Ein.stl while the snappyHexMeshDict called for ImportOFkl_3Dchannel_Ein_neu.stl.
My version of OF is 2312.
The generated shape is shown in the attachment.
For future reference:
1. Reduce number of cells in the blockmesh to get it to run quicker.
2. Provide your system and constant directories as well as your "run" or "Allrun" file to save me effort setting that up.
wkernkamp is offline   Reply With Quote
Old   May 13, 2024, 07:42
Thank you very much for your answer!
I still don't know where my error was but I managed to mesh my case by setting up everything from start in a new run folder.
And thank you for your tips, I will keep that in mind for my next post
snappyhexmesh;
[OpenFOAM.com] Openfoam solvers and snappyHexMesh stopped working in parallel after update KTG OpenFOAM Installation 9 February 14, 2021 03:14
[snappyHexMesh] reconstructPar after running snappyhexmesh in parallel fidu OpenFOAM Meshing & Mesh Conversion 11 October 20, 2020 10:01
[snappyHexMesh] SnappyHexMesh : snapping not matching surface Awak OpenFOAM Meshing & Mesh Conversion 4 May 31, 2016 09:23
interDyMFoam Floating Object with snappyHexMesh not working ocalloc OpenFOAM Running, Solving & CFD 1 May 27, 2016 10:42
[snappyHexMesh] snappyHexMesh stops working at "edge intersection testing" electron OpenFOAM Meshing & Mesh Conversion 3 November 12, 2012 17:53
