May 8, 2024, 12:27 |
splitMeshRegion Face Zones
Terence
Rep Power: 2 |
I've successfully converted a .unv to foam with the command ideasUnvToFoam. This is the output:
Of 11686 so-called boundary faces 8380 belong to two cells and are therefore internal Sorting boundary faces according to group (patch) 0: firebrick is cellZone 1: fluid is cellZone 2: heater is cellZone 3: fluid_inlet is patch 4: firebrick_external is patch 5: firebrick_inlet is patch 6: firebrick_outlet is patch 7: firebrick_to_fluid is faceZone 8: heater_external is patch 9: heater_to_firebrick is faceZone 10: heater_to_fluid is faceZone 11: heater_outlet is patch 12: heater_inlet is patch 13: firebrick_to_heater is faceZone Constructing mesh with non-default patches of size: fluid_inlet 90 firebrick_external 2151 firebrick_inlet 206 firebrick_outlet 152 heater_external 625 heater_outlet 31 heater_inlet 51 Adding cell and face zones Cell Zone fluid 67488 Cell Zone firebrick 74315 Cell Zone heater 1639 Face Zone heater_to_firebrick 240 Face Zone firebrick_to_heater 52 Face Zone heater_to_fluid 189 Face Zone firebrick_to_fluid 7899 End The intent is to be able to see all of the separated regions in paraview. Unfortunately, I am only able to see the volume regions (cell zones) for each part of the mesh and none of the boundary regions (patches) using the Extract Block filter. I can see all the regions fine with vtkBlockColors. Last edited by tfisherira; May 8, 2024 at 12:34. Reason: extract block filter |
May 14, 2024, 05:09 |
Yann
Rep Power: 29 |
Hello Terence,
How do you load your case in ParaView ? with paraFoam or with the ParaView native OpenFoam reader ? In ParaView, do you see patches in the Mesh Regions zone? |
cellzones, facezone, regions, splitmeshregions |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
[snappyHexMesh] snappyHexMesh does not detect highly skewed faces? | ptpacheco | OpenFOAM Meshing & Mesh Conversion | 1 | January 4, 2022 13:37 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[simpleFoam] Floating point exception | seuchsy | OpenFOAM Running, Solving & CFD | 3 | November 3, 2016 10:29 |
Hydrostatic Pressure and Gravity | miliante | OpenFOAM Running, Solving & CFD | 132 | October 7, 2012 23:50 |
