[Other] Floating point exception error in foam-extend 5.0 |
April 17, 2024, 23:40 |
Na.Li
I am learning to use the immersed boundary method in foam-extend 5.0 to simulating identify the grids around a wind turbine. The error occured when I used writeIbMasks to identify the grids around the wind turbine. I found if I used model rotor.ftr, the command of writeIbMasks runs normally. When I used the model tower.ftr, there was also no error. Then I assembled these two parts by the SolidWorks and exported Windturbine.stl and Windturbine.ftr. Something wrong happens when I use Windturbine.ftr for writeIbMasks in foam-extend 5.0. A Floating point exception is displayed. I have looked at the source code writeIbMasks.C, but I still have no idea. Finally i got the IbMasks by unsetting FOAM_SIGFPE,but i don't know if this approach will have any other impacts. Thanks, any help would be much appreciated, as I am pulling my hair out here, trying to figure this out.
Thanks Na.Li |
writeibmasks |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
Floating point exception (PLEASE HELP :) ) | mn14cat | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 9 | December 8, 2021 12:24 |
ERORR floating point exception fluent udf | cudau.95 | Fluent UDF and Scheme Programming | 0 | August 4, 2021 23:11 |
simpleFoam: floating point exception | student666 | OpenFOAM Running, Solving & CFD | 9 | March 13, 2016 19:23 |
Temperature floating point exception | ayckrom | FLUENT | 1 | May 13, 2015 10:02 |
