[snappyHexMesh] Suggestions for meshing (snappyHexMesh) |
April 15, 2024, 22:39 |
Hello everyone,
I am currently working with my gas turbine combustor model. I need some suggestions for meshing the current model. I am hereby going to explain, what I have tried until now. 1) To do an internal mesh using snappyHexMesh, I created a box around my actual geometry. (Fig. 1. Computational domain inside the box) 2) Then, based on fixing appropriate coordinates in locationInMesh, I could able to create an internal mesh (Fig. 2. Internal mesh in the combustor). The mesh is not fine in center of combustor regime with still little distortion in domain shape. 3) One of my friends recommend me to use STAR CCM+ for good mesh with quick adaptability that saves time (Fig. 3. Mesh in STAR CCM+). However, I prefer using snappyHexMesh or any other open-source tools in order to understand the art of meshing. I would like to learn things perfectly, even though it can take a while at times. I would like to know the following: 1) May I ask if the above steps I am following step-by-step are correct? I need to play with as many parameters that are present in snappyHexMeshDict file to get my expected mesh. 2) Can someone suggest me snappyHexMesh learning tutorials ? 3) Or should I need to adopt other opensource tools like GMSH (or) Salome ? Thank you Kindly correct me and give some valuable suggestions. |
April 22, 2024, 21:22 |
#2 | ||||
I played with snappyHexMesh parameters and got a reasonable mesh.
Hope this helps someone. Thank you |
gasturbinecombustor, snappyhexmesh |
PROBLEM USING rhoCentralFoam AND snappyHexMesh | davidvzq | OpenFOAM Running, Solving & CFD | 0 | May 27, 2021 00:01 |
[snappyHexMesh] snappyHexMesh running | lguillem | OpenFOAM Meshing & Mesh Conversion | 7 | June 13, 2014 11:28 |
[snappyHexMesh] Error in SnappyHexMesh | gooya_kabir | OpenFOAM Meshing & Mesh Conversion | 2 | October 23, 2013 04:41 |
[snappyHexMesh] SnappyHexMesh | samiam1000 | OpenFOAM Meshing & Mesh Conversion | 0 | October 5, 2009 10:32 |
[snappyHexMesh] Problem with snappyHexMesh | samiam1000 | OpenFOAM Meshing & Mesh Conversion | 0 | October 3, 2009 05:08 |
