[blockMesh] How to make a cylinder mesh that the cells dense inside and sparse outside
Old   April 11, 2024, 10:33
Default How to make a cylinder mesh that the cells dense inside and sparse outside
Huang, Ching-Chan
Allen_Huang is on a distinguished road
How to make a cylinder mesh that is Dense inside and sparse outside, I have try this video but there were some error when I used checkMesh. https://youtu.be/3v50ev75aDw?si=LvcrGvT77deIaMp1
Allen_Huang is offline   Reply With Quote
Old   April 12, 2024, 05:59
M
AtoHM is on a distinguished road
If I understand your target correctly, you cannot do that with blockMesh alone. It is very basic with snappyHexMesh, though. Just create a big blockMesh (cube) with the spacing you want to have "on the outside" and then you can use a searchableCylinder source in snappyHexMesh (defined in the geometry section of the snappyHexMeshDict) and add a volumetric refinement for that region inside the refinementRegions section of the snappyHexMeshDict. This is a very basic thing and should be easily found in tutorials online.
AtoHM is offline   Reply With Quote
blockmesh, blockmesh cylinder, cylinder, negative
