[snappyHexMesh] Facing challenges with snappyHexMeshDict |
April 10, 2024, 04:48 |
Dereje Arijamo
I hope you are all fine and doing well. I have one issue with meshing and it is stated below.
I am meshing NACA0015 using snappyHexMeshDict, but the wall (edge) of the airfoil edge becomes deformed once the mesh is refined. I am not that much an expert in snappyHexMesh, so I am looking for your help. As well as my snappyHexMeshDict code, I have attached the image that came from Paraview. Thank you!!! /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 8 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // castellatedMesh true; snap true; addLayers true; geometry { wing { type triSurfaceMesh; file "wing.obj"; } refinementBox { type searchableBox; min (-1 -1 -0.1875); max ( 3.5 1 0.1875); } } castellatedMeshControls { maxLocalCells 250000000; maxGlobalCells 500000000; minRefinementCells 0; nCellsBetweenLevels 8; maxLoadUnbalance 0.1; features ( ); resolveFeatureAngle 60; refinementSurfaces { wing { // Surface-wise min and max refinement level level (6 8); } } locationInMesh (1.25 0.5 0.025); refinementRegions { refinementBox { mode inside; levels ((1e15 2)); } } allowFreeStandingZoneFaces true; } snapControls { nSmoothPatch 3; tolerance 2.0; nSolveIter 100; nRelaxIter 5; //nFeatureSnapIter 5; } addLayersControls { relativeSizes false; layers { wing { nSurfaceLayers 4; } } expansionRatio 1.3; finalLayerThickness 0.003125; minThickness 0.00000001; nGrow 0; featureAngle 60; nRelaxIter 5; nSmoothSurfaceNormals 1; nSmoothNormals 3; nSmoothThickness 8; maxFaceThicknessRatio 0.5; maxThicknessToMedialRatio 0.3; minMedianAxisAngle 90; nBufferCellsNoExtrude 0; nLayerIter 50; } meshQualityControls { maxNonOrtho 65; maxBoundarySkewness 20; maxInternalSkewness 4; maxConcave 80; minVol 1E-13; minTetQuality 1E-30; minArea 1E-13; minTwist 0.05; minDeterminant 0.001; minFaceWeight 0.05; minVolRatio 0.01; minTriangleTwist -1; //Advanced nSmoothScale 4; errorReduction 0.8; } //Advanced debug 0; mergeTolerance 1E-06; // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // |
Long simulation time (Backward Facing Step) | nskelly | OpenFOAM Running, Solving & CFD | 3 | March 6, 2018 11:59 |
facing problem with udf | sachin61091 | Fluent UDF and Scheme Programming | 0 | January 14, 2016 02:10 |
[snappyHexMesh] How to define the computational region with snappyHexMeshDict | xurenyi | OpenFOAM Meshing & Mesh Conversion | 3 | June 12, 2014 10:20 |
Fluent and backwards facing step | Ben Sellars | Main CFD Forum | 2 | February 3, 2007 13:36 |
backward facing step | ryoga | Main CFD Forum | 1 | March 9, 2003 03:52 |
