[blockMesh] Mesing a polar cylinder in x-direction
Old   April 4, 2024, 15:39
Default Mesing a polar cylinder in x-direction
Marķa Rosales
MMRC is on a distinguished road
Good day community,
Please, can you give me a hand in the block definition. I want to elaborate a cylindrical geometry, radial directions in y & z, and length along x-axis. The grid that I want is polar so I wanted to reproduce 4 times a quarter of cylinder but I got stucked in the block definition:
scale               1;
cx 0.0;
cy 0.0;
cz 80.0;
height 3;
r 45;
h #calc "$height+$cx";
vz #calc "$cz+$r";
nvz #calc "$cz-$r";
vy #calc "$cy+$r";
nvy #calc "$cy-$r";
c1 #calc "$cz + ($r*cos(45.0))"; // cosine in first quadrant
s1 #calc "$cy + ($r*sin(45.0))"; // sine
c2 #calc "$cz + ($r*cos(135.0))"; // cosine in first quadrant
s2 #calc "$cy + ($r*sin(135.0))"; // sine
c3 #calc "$cz + ($r*cos(225.0))"; // cosine in first quadrant
s3 #calc "$cy + ($r*sin(225.0))"; // sine
c4 #calc "$cz + ($r*cos(315.0))"; // cosine in first quadrant
s4 #calc "$cy + ($r*sin(315.0))"; // sine
vertices
($cx $cy $nvz) //0
($h $cy $nvz) //1
($h $vy $cz) //2
($cx $vy $cz) //3
($cx $nvy $cz) //4
($h $nvy $cz) //5
($h $cy $vz) //6
($cz $cy $vz) //7
($cx $cy $cz) //8
($h $cy $cz) //9
blocks
    hex (8 4 0 8 9 5 1 9) (1 15 15) simpleGrading (1 1 1)
    hex (8 0 3 8 9 1 2 9) (1 15 15) simpleGrading (1 1 1)
    hex (8 3 7 8 9 2 6 9) (1 15 15) simpleGrading (1 1 1)
    hex (8 7 4 8 9 6 5 9) (1 15 15) simpleGrading (1 1 1)
edges
    arc 0 1 ($cx $s1 $c1)
    arc 1 2 ($cx $s2 $c2)
    arc 2 3 ($cx $s3 $c3)
    arc 3 0 ($cx $s4 $c4)
    arc 4 5 ($h $s1 $c1)
    arc 5 6 ($h $s2 $c2)
    arc 6 7 ($h $s3 $c3)
    arc 7 4 ($h $s4 $c4)
The error in terminal is:
Creating block edges
No non-planar block faces defined
Creating topology blocks
--> FOAM Warning :
    From Foam::vector Foam::cellModel::centre(const labelList&, const Foam::UList<Foam::Vector<double> >&) const
    in file meshes/meshShapes/cellModel/cellModel.C at line 63
    zero or negative pyramid volume: -12487.5 for face 1
--> FOAM Warning :
    zero or negative pyramid volume: -6243.75 for face 3
--> FOAM Warning :
    zero or negative pyramid volume: -2868.75 for face 4
--> FOAM Warning :
    zero or negative pyramid volume: -2868.75 for face 5
--> FOAM FATAL IO ERROR: (openfoam-2306)
Block hex (8 3 7 8 9 2 6 9) (1 15 15) grading (1(1) 1(1) 1(1)) has inward-pointing faces
    4(3 7 6 2) 4(8 9 6 7) 4(8 8 7 3) 4(9 2 6 9)
file: system/blockMeshDict.blocks at line 68.
    From void Foam::blockDescriptor::check(const Foam::Istream&)
    in file blockDescriptor/blockDescriptor.C at line 147.
FOAM exiting
Any comments are welcome
MMRC is offline   Reply With Quote
Old   April 5, 2024, 07:46
Matthias Renaud
MatthiasR is on a distinguished road
Hola Maria,
I see a few errors in your blockMeshDict file.
First I assume the cos and sin function to take angle in rad as inputs, you could also used sqrt(2) just as I did.
Second your vertex 7 in not defined correctly, it should be ($cx $cy $vz)
you wrote $cz instead.
And last all your edges are wrong, there should be no arc between vertices 0 and 1, 6 and 7, 4 and 5, 2 and 3. Below is my version of the blockMeshDict (it works):
scale 1;
cx 0.0;
cy 0.0;
cz 80.0;
height 3;
r 45;
vz #calc "$cz+$r";
nvz #calc "$cz-$r";
vy #calc "$cy+$r";
nvy #calc "$cy-$r";
c1 #calc "$cz + ($r / sqrt(2.0))"; // cosine in first quadrant
s1 #calc "$cy + ($r / sqrt(2.0))"; // sine
c2 #calc "$cz - ($r / sqrt(2.0))"; // cosine in first quadrant
s2 #calc "$cy + ($r / sqrt(2.0))"; // sine
c3 #calc "$cz - ($r / sqrt(2.0))"; // cosine in first quadrant
s3 #calc "$cy - ($r / sqrt(2.0))"; // sine
c4 #calc "$cz + ($r / sqrt(2.0))"; // cosine in first quadrant
s4 #calc "$cy - ($r / sqrt(2.0))"; // sine
vertices
    ($cx $cy $nvz) //0
    ($h $cy $nvz) //1
    ($h $vy $cz) //2
    ($cx $vy $cz) //3
    ($cx $nvy $cz) //4
    ($h $nvy $cz) //5
    ($h $cy $vz) //6
    ($cx $cy $vz) //7
    ($cx $cy $cz) //8
    ($h $cy $cz) //9
blocks
    hex (8 4 0 8 9 5 1 9) (15 15 15) simpleGrading (1 1 1)
    hex (8 0 3 8 9 1 2 9) (15 15 15) simpleGrading (1 1 1)
    hex (8 3 7 8 9 2 6 9) (15 15 15) simpleGrading (1 1 1)
    hex (8 7 4 8 9 6 5 9) (15 15 15) simpleGrading (1 1 1)
edges
    arc 7 3 ($cx $s1 $c1)
    arc 6 2 ($h $s1 $c1)
    arc 3 0 ($cx $s2 $c2)
    arc 2 1 ($h $s2 $c2)
    arc 0 4 ($cx $s3 $c3)
    arc 1 5 ($h $s3 $c3)
    arc 4 7 ($cx $s4 $c4)
    arc 5 6 ($h $s4 $c4)
Have a nice day,
Matthias
MatthiasR is offline   Reply With Quote
Old   April 5, 2024, 11:38
Marķa Rosales
MUCHAS GRACIAS Matthias,
The cylinder worked with your solution!
Here I share how the blockMesh would look like:
scale 1;
cx 0.0;
cy 0.0;
cz 80.0;
height 3;
r 45;
vz #calc "$cz+$r";
nvz #calc "$cz-$r";
vy #calc "$cy+$r";
nvy #calc "$cy-$r";
vertices
    ($cx $cy $nvz) //0
    ($h $cy $nvz) //1
    ($h $vy $cz) //2
    ($cx $vy $cz) //3
    ($cx $nvy $cz) //4
    ($h $nvy $cz) //5
    ($h $cy $vz) //6
    ($cx $cy $vz) //7
    ($cx $cy $cz) //8
    ($h $cy $cz) //9
blocks
    hex (8 4 0 8 9 5 1 9) (15 15 1) simpleGrading (1 1 1)
    hex (8 0 3 8 9 1 2 9) (15 15 1) simpleGrading (1 1 1)
    hex (8 3 7 8 9 2 6 9) (15 15 1) simpleGrading (1 1 1)
    hex (8 7 4 8 9 6 5 9) (15 15 1) simpleGrading (1 1 1)
edges
boundary
    upwind
        type patch;
        faces
    (8 0 4 8)
    (8 3 0 8)
    (8 7 3 8)
    (8 4 7 8)
    sides
        type patch;
        faces
    (0 4 5 1)
    (7 6 2 3)
    (5 6 7 4)
    (3 2 1 0)
    leeward
        type patch;
        faces
    (9 6 5 9)
    (9 5 1 9)
    (9 1 2 9)
    (9 2 6 9)
mergePatchPairs
blockmesh, blockmesh cylinder, mesh
Problem with verification of transverse freely moving cylinder aakie OpenFOAM Running, Solving & CFD 4 August 3, 2019 10:01
[blockMesh] Cylinder mesh using blockMesh with m4 macro Lewis Liang OpenFOAM Meshing & Mesh Conversion 2 November 21, 2017 03:28
[ANSYS Meshing] uniform mesh, cylinder with a cut Matiasi ANSYS Meshing & Geometry 5 June 8, 2015 16:08
I need help about velocity vectors direction in cylinder modeling!!! aminepoxnet FLUENT 0 March 17, 2013 18:41
Drag on non-infinite cylinder between parallel walls deltaquattro Main CFD Forum 0 September 10, 2009 14:01
