[snappyHexMesh] Another addLayersControls problem |
March 30, 2024, 13:59 |
Vadim Mikhailov
Rep Power: 3 |
Hello everyone! I`m very new in OpenFOAM and in using snappyHexMesh utility and not clearly understand the problem i face with
I try to simulate the flow around a bullet or a projectile and the mesh at all is fine(i have a 99.2% of layers coverage), but in corners at nose and boattail there are less layers (on pictures) Now i have read a lot of threads on this forum and try increase resolveFeatureAngle to solve this problem. But the quality of my mesh doesnt improved. Here is all my project https://disk.yandex.ru/d/s1lt1GIX8SU_kg And all my snappeHexMeshDict Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap true; addLayers true; geometry { shell1.stl { type triSurfaceMesh; name projectile_stlSurface; //To get regions in the STL regions { projectile // Named region in the STL file { name projectile; // User-defined patch name } } } refinementBox { type searchableBox; min (-0.5 -0.15 -0.15); max (0.75 0.15 0.15); } }; // Settings for the castellatedMesh generation. castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ maxLocalCells 500000; maxGlobalCells 10000000; minRefinementCells 0; maxLoadUnbalance 0.10; nCellsBetweenLevels 3; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ features ( { file "shell1.eMesh"; level 6; //level 4; } ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ refinementSurfaces { projectile_stlSurface { // global // Surface-wise min and max refinement level level (7 7); } } // Feature angle: // resolveFeatureAngle 30; //recommended resolveFeatureAngle 60; //To avoid too much refinement with curvature planarAngle 30; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ refinementRegions { refinementBox { mode inside; // inside - outside levels ((4 4)); // min max //mode distance; // //levels ((0.1 1)); //first number distance normal to the surface in both direction } } // Mesh selection // ~~~~~~~~~~~~~~ locationInMesh (2.0 0.5 0.5); allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { // nSmoothPatch 2; //recommended nSmoothPatch 10; //improved tolerance 2.0; //tolerance 1.0; nSolveIter 5; //recommended //nSolveIter 100; //improved nRelaxIter 5; //recommended //nRelaxIter 10; //improved 10-20-50 // Feature snapping nFeatureSnapIter 3 //recommended //nFeatureSnapIter 100; //improved 20-50-100 implicitFeatureSnap false; explicitFeatureSnap true; multiRegionFeatureSnap false; } // Settings for the layer addition. addLayersControls { relativeSizes true; expansionRatio 1.2; firstLayerThickness 0.01; minThickness 0.01; layers { projectile { nSurfaceLayers 20; } } nGrow 0; // Advanced settings featureAngle 359; maxFaceThicknessRatio 0.5; nSmoothSurfaceNormals 2; nSmoothThickness 10; minMedialAxisAngle 90; minMedianAxisAngle 90; maxThicknessToMedialRatio 0.3; nSmoothNormals 3; slipFeatureAngle 80; nRelaxIter 5; nBufferCellsNoExtrude 0; nLayerIter 10; nRelaxedIter 10; } // Generic mesh quality settings. At any undoable phase these determine where to undo. meshQualityControls { #include "meshQualityDict" relaxed { // Maximum non-orthogonality allowed. Set to 180 to disable. maxNonOrtho 75; } //minFlatness 0.5; // Advanced // Number of error distribution iterations nSmoothScale 4; // amount to scale back displacement at error points errorReduction 0.75; } // Advanced //// Debug flags debugFlags ( //mesh // write intermediate meshes //intersections // write current mesh intersections as .obj files //featureSeeds // write information about explicit feature edge refinement //attraction // write attraction as .obj files // layerInfo // write information about layers ); // //// Write flags writeFlags ( scalarLevels // write volScalarField with cellLevel for postprocessing layerSets // write cellSets, faceSets of faces in layer layerFields // write volScalarField for layer coverage ); mergeTolerance 1e-6; // ************************************************************************* // |
boundary layer control |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 05:37 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 06:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 07:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
