[Other] Numerical wave tank simulating linear waves with cyclic boundary conditions |
March 30, 2024, 08:18 |
abdulsalam musaad
Rep Power: 2 |
Hi everyone! i am new to OpenFoam (first Thread).
I am trying to simulate a 2D Numerical wave tank with cyclic boundary conditions for the inlet and the outlet. i started from the stokes 1 example of OpenFoam v2306. in the example the waves are generated at the inlet. So, my problem now is how can i create the waves without the waveAlpha condition at the inlet? should i create a nonuniform alpha.water , p_rgh , U files? and how can i do that in a practical way? i tried running the stokes 1 example until it reaches a developed stage, then change the boundary conditions in the fields files. but i could not make it to work and it is not ideal for my intended use. ideally i want to impose the theoretical stokes 1 solution and see how much the numerical solution will deviate form the theoretical solution due to spatial and temporal discretisation excluding the wave generation and absorption errors. sorry if it is a basic question. it would be very helpful if you can provide me with examples. Thanks in advance. |
March 31, 2024, 16:07 |
posting my solution for reviewing
abdulsalam musaad
Rep Power: 2 |
I am posting my solution to this problem for reviewing, suggestions and hopefully the benefit of others. Note that i am not 100% sure if this is the best and most correct way to do it. but it looks fine from what i saw.
what i did basically is initializing the VOF (alpha) and the velocity at time zero using codeStream and let openfoam deal with calculating the pressure. i relied on "water wave mechanics for engineering and scientists" as a reference for the theoretical equations of the velocity and water surface shape. Cheers Last edited by AbdoMusaad; March 31, 2024 at 17:12. |
v10 pimpleFOAM: Rotational cyclicAMI boundary conditions face Weight going to 0 | nialloneill | OpenFOAM Running, Solving & CFD | 2 | January 23, 2024 18:53 |
psi in the rhoThermo class | cryabroad | OpenFOAM Running, Solving & CFD | 10 | October 21, 2020 06:09 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 19:02 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
