[snappyHexMesh] sHM and multi-region Meshing
Old   March 26, 2024, 06:07
Default sHM and multi-region Meshing
Sebastian Thaler
sebastian_t is on a distinguished road
Hey,
i am fairly new to OF (working on it as part of my internship). We are using OpenFoam Version 11. I want to setup a CHT case and for practice i looked at the tutorialcase CHT/heatedDuct. Now i have some questions:
- I think i have understood the principle of how cells are assigned to zones with help of the refinementSurfaces sub-dictionary and why the geometry is setup, so that all outer faces are in one stl-file and the inner faces are in seperate stl-files. Is this the preferred way? (i stumbled about other options e.g. with topoSet)
- Is there a way to refine the inner-surfaces just in one direction? especially with a higher number of nCellsBetweenLayers
- Is there a way to refine a cellZone (region) directly or with the refineRegions sub-dict with this geometry sub-dict.
- Maybe a general question to the snap feature. Does it snap to all geometries defined in the sub-dict (with explicitFeatureSnap)?
- Or would it be better to go with implicitFeatureSnap and define the wanted features?
- what does multiRegionFeatureSnap do?
- how can I add layers on the inner-surfaces (preferably just on one side)
I have worked with the UserGuide on cfd.direct, the annotated dicts with foamGet and several other ressources on the web but i find it quite hard to get forward. Some answers would be much appreciated.
best regards
Sebastian
sebastian_t is offline   Reply With Quote
multi region, snapphhexmesh
[snappyHexMesh] Multi region meshing with SHM creates extra regions Dav3dum OpenFOAM Meshing & Mesh Conversion 0 August 8, 2016 09:54
[snappyHexMesh] New multi region meshing tutorial with sHM Tobi OpenFOAM Meshing & Mesh Conversion 0 November 24, 2014 18:42
[snappyHexMesh] Multi region meshing & recovering the original patch names fluidpath OpenFOAM Meshing & Mesh Conversion 4 May 19, 2013 20:13
[snappyHexMesh] multi region laplacian OpenFOAM Meshing & Mesh Conversion 1 July 20, 2012 07:49
[snappyHexMesh] Multi Region Meshing with sHM marango OpenFOAM Meshing & Mesh Conversion 3 March 27, 2012 01:51
