[Other] dynamicMesh
Old   February 19, 2024, 13:07
Question dynamicMesh
onurlands
onurcanpiskin is on a distinguished road
Hello, I want to solve an oblique shooting problem. Imagine that a solid object has x and y speed, it moves from a point and falls to the ground again. I want to simulate this and also calculate where it will fall. For this, I need to apply dynamic mesh, but I have not applied dynamic mesh before and I usually do the meshing process through Salome. I'm having trouble creating the case file.
What should I do after wiping over Salome?
For example, imagine a boundary volume and there is a stone at one point inside it. The oblique throw of that stone will happen. Do I need to remove that stone from the boundary volume before meshing in Salome?
Is it enough to define only the boundary volume and the stone and how will I define them?
I couldn't see a similar example, so frankly I couldn't determine exactly which solver to use. I would really appreciate it if you could help me.
onurcanpiskin is offline   Reply With Quote
dynamicmesh
How to set up correctFluxes in dynamicMesh? qiancg OpenFOAM Running, Solving & CFD 0 February 22, 2023 10:30
DynamicMesh for Fish Motion ShinGS OpenFOAM Running, Solving & CFD 1 February 13, 2023 03:11
InterFoam and dynamicMesh fatal error Rasmusiwersen OpenFOAM Running, Solving & CFD 11 February 23, 2020 05:51
An error about the dynamicmesh file of pimpleDymFoam zxzx OpenFOAM Running, Solving & CFD 4 January 14, 2017 18:49
External management of solid motion (using dynamicmesh) maxou1993 Main CFD Forum 0 July 28, 2015 12:37
