[Salome] Salome Meshing (Solid in the fluid)
Old   February 15, 2024, 07:17
Default Salome Meshing (Solid in the fluid)
onurlands
onurcanpiskin is on a distinguished road
Hello, I have a few questions I want to ask. Think of a boundary volume, this boundary volume is completely filled with air and I have an object inside this boundary volume, I want to analyze the movement of this object in this air on openfoam and display where this piece will fall. I want to apply the mesh operation without salome, but do I need to remove the object inside the boundary volume from the boundary volume? Has anyone encountered such a problem? I would be very glad if you could help me with this.
onurcanpiskin is offline   Reply With Quote
salome, solid, vof
[solids4Foam] How to calculate drag coeff when using solids4Foam amuzeshi OpenFOAM CC Toolkits for Fluid-Structure Interaction 15 November 7, 2019 13:50
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 06:07
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
heat conducting solid within a fluid medium? sieginc. STAR-CCM+ 1 February 19, 2012 12:48
