[Other] Is it possible to create faceZones in Ansys Mesh? |
February 8, 2024, 04:55 |
Rajesh
Rep Power: 3 |
Hello.
I happen to use dsmcFoam+ and would like to create faceZones. I do not understand the process of making faceZones, is it supposed to be made before meshing, similar to how patches are made using named selections? |
February 12, 2024, 07:01 |
Rep Power: 5 |
Hey!
If you have created named selections for internal faces, these selections should appear as faceZones once you import it in OpenFoam (make sure you choose internal if you are using fluent meshing). |
flow over cylinder in openFoam | saeed jamshidi | OpenFOAM Pre-Processing | 3 | August 11, 2023 16:16 |
Create polyhedral mesh in ANSYS Mesh | CFD10111 | Main CFD Forum | 2 | September 6, 2022 08:51 |
[ANSYS Meshing] ANSYS mesh - I was surprised... | assafwei | ANSYS Meshing & Geometry | 0 | September 4, 2014 13:17 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
[ICEM] how to create a 2d tri mesh with quad mesh in the boundary layer | seal2013 | ANSYS Meshing & Geometry | 3 | October 6, 2013 17:09 |
