[snappyHexMesh] blockmesh edge problem with snappyhexmesh
Old   February 4, 2024, 19:40
Default blockmesh edge problem with snappyhexmesh
önay bilgen
onaybilgen is on a distinguished road
I want to do a propeller analysis using the srfsimplefoam solver. As seen in the pictures below, I get an error when I place the propeller where I want. But when I move the propeller to the middle, I don't get any errors. I made the flow field with blockmesh. Thank you in advance for your help
onaybilgen is offline   Reply With Quote
Old   February 4, 2024, 19:51
Burhan Göktürk
GokturkBurhan is on a distinguished road
I am also facing the same problem. But I don't know the solution .
GokturkBurhan is offline   Reply With Quote
[snappyHexMesh] Problem with skewd faces in SnappyHexMesh Friendly OpenFOAM Meshing & Mesh Conversion 1 June 19, 2019 08:05
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 18:16
[snappyHexMesh] Problem in results with snappyHexMesh between refinement levels Phil_WO OpenFOAM Meshing & Mesh Conversion 2 November 8, 2018 04:49
[snappyHexMesh] problem with snappyHexMesh kanes OpenFOAM Meshing & Mesh Conversion 10 January 26, 2016 07:11
[snappyHexMesh] Problem with snappyHexMesh samiam1000 OpenFOAM Meshing & Mesh Conversion 2 December 13, 2012 09:41
