[snappyHexMesh] doesn't fit the geometry what i expected |
January 21, 2024, 12:27 |
Hyein
Rep Power: 2 |
hi I try to simulate the square ribs in duct in quasi 2 dimension.
I generate the geometry of duct using block mesh and using stl file I intended to inplement the square ribs and then generate mesh with sHM. After commanding sHM in terminal i got this geometry (see attatched picture error) What i expected was like in file (squareribs) You can see the ribs doesn't fit what i made in stlfile. Does anyone know what is the problem? |
January 22, 2024, 05:05 |
Yann
Rep Power: 29 |
Just to make sure, have you run snappyHexMesh with the -overwrite option? If not, have you moved to the last timestep in ParaView to visualize your mesh? I'm suspecting your screenshots could show the castellated mesh and not the snapped mesh. Yann |
January 22, 2024, 06:52 |
Hyein
Rep Power: 2 |
Thank you for your reply. Yes I realized the process is not finished yet. But I finished now. And I have new question do you have any tips to combine the boundary? Bc I want to give the heat on the bottom so that I can see how efficient the ribs depending on the shape. Since I set the block mesh as a duct and ribs using snappyhexMesh, I have teo boundary for heated wall. How can I combine or redefine the boundary?
January 22, 2024, 06:55 |
Hyein
Rep Power: 2 |
I am considering now with toposet btw… Is it possible with toposet?
January 22, 2024, 09:09 |
Yann
Rep Power: 29 |
Yes you can do it with topoSet.
Or just define the boundary condition you want to use on both patches. |
January 22, 2024, 09:23 |
Hyein
Rep Power: 2 |
Thank you!
One more question about the 2. option. So if I group the bottom wall from block mesh and the square ribs in boundary condition and give the heat flux in vertical direction, then the heat flux is automatically applied on surfaces of the square ribs and bottom wall except for where the ribs exist? |
January 22, 2024, 09:38 |
Yann
Rep Power: 29 |
What boundary condition do you intend to use?
January 27, 2024, 14:37 |
Hyein
Rep Power: 2 |
I always thank you yann for helping me!!
Using externalWallHeatFluxTemperature constant heat flux. I just tried to group the wall where the heat is applied (bottom wall and square ribs) using createpatchdict. Because the bottom wall I defined by blockMesh is removed automatically where the squareribs exist. But I realized that the heat isn't applied at all on the squareribs in this way. So I undo the grouping the both boundaries. During running the simulation I check the heat flux value using wallHeatFlux (postprocessin utility) on the bottomwall and it doesn't correspond to the value I specified... less than what i gave... Is there any other way to apply both boundaries equal value of heat flux? |
January 30, 2024, 05:45 |
#9 | |
Yann
Rep Power: 29 |
I'm not sure what is going on, but I think whether you have one single patch or several patch should not matter, both should get the specified heat flux once the solution converged. (did it?) Quote:
How do I connect a geometry to my solver | devansh.purohit | Main CFD Forum | 4 | November 16, 2021 09:51 |
Question about Geometry vs. Meshes | EphemeralMemory | ANSYS Meshing & Geometry | 2 | December 8, 2016 14:02 |
The udf.h headers are unable to open- in VISUAL STUDIO 13 | sanjeetlimbu | Fluent UDF and Scheme Programming | 4 | May 2, 2016 06:38 |
Running CFD parallel. There is no geometry file! | CrashLaker | SU2 | 6 | April 10, 2014 04:08 |
[CAD formats] translating geometry from Abaqus to OpenFOAM | skuznet | OpenFOAM Meshing & Mesh Conversion | 3 | January 10, 2014 14:49 |
