[snappyHexMesh] Collapsing cells nearby internal geometry vertices |
January 14, 2024, 09:36 |
Rep Power: 13 |
Dear All,
I am trying to use snappy to mesh a nozzle geometry. I am using explicit feature refinement and the domain geometry is well resolved, except at some internal points. As you can see from the pics below, some cells around vertices (marked in red) are squished/collapsed nearby a geometric vertex. Looking at the castellated mesh, I noticed that already prior to snapping some flat cells appear in the mesh. I wanted to ask if any of you experienced the same issue and eventually, how to fix the problem. I already tried several snappy dictionary tweaks, changing resolution levels, mesh quality thresholds etc., but nothing has helped so far... |
collapse, point, snap to surface, snappyhexmesh, vertex |
[snappyHexMesh] Too many cells in undesired part, very less cells in desirable part | Ash Kot | OpenFOAM Meshing & Mesh Conversion | 3 | August 7, 2023 15:56 |
SimpleFoam & Theater | jipai | OpenFOAM Running, Solving & CFD | 3 | June 18, 2019 11:11 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 18:16 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
