[snappyHexMesh] SnappyHexMesh should visible with colors based on refinement levels |
November 1, 2023, 10:30 |
Cherry
Hello all,
I have created a snappyHexMesh with refinement level 4 in openFOAM. But I wanted to visualize mesh in different colors as we get mesh from ANSYS. I wanted to implement same thing in openFOAM, is it possible to do that. If anyone knows this you can give a reply. Thanks |
November 1, 2023, 11:44 |
M
Rep Power: 12 |
please imagine someone asking you the question you are just asking. What would you reply? Your question is too vague to give any meaningful reply. Guide: How to ask a question on the forums |
#meshing, #openfoamcase |
[snappyHexMesh] snappyHexMesh does not work | Siassei | OpenFOAM Meshing & Mesh Conversion | 8 | September 28, 2023 04:01 |
[snappyHexMesh] Not Able to Refine Mesh in Refinement Box | noodleluvmay | OpenFOAM Meshing & Mesh Conversion | 2 | January 27, 2020 10:55 |
[snappyHexMesh] SnappyHexMesh edge not snaped correctly | yongxiang | OpenFOAM Meshing & Mesh Conversion | 2 | October 25, 2019 09:11 |
[snappyHexMesh] snappyHexMesh refinement regions ignored | guitarbren | OpenFOAM Meshing & Mesh Conversion | 2 | April 9, 2013 03:59 |
[snappyHexMesh] Bumpy Wing with snappyHexMesh | aeir1976 | OpenFOAM Meshing & Mesh Conversion | 9 | June 20, 2012 05:30 |
