[Technical] First cell height when Re = 50 million |
I am trying to generate a mesh for a high Re number case (flow over ship propellers):
Re = 50 million Turbulence model: k-omega SST The issue is that for y+ <5, the estimated first cell height is extremely small (2e-6m which makes it almost impossible to run. Not only the number of cells in the grid is high, but also the time step is extremely small. Any suggestions to make the case practical? |
high reynolds number, hydrofoil, k-omega sst |
[ANSYS Meshing] Consideration of first cell height of prism layer for laminar flow in heat transfer p | swapnil13 | ANSYS Meshing & Geometry | 0 | September 8, 2019 03:42 |
Fluent UDF wrong number of cells in parallel - correct in serial | dralexpe | Fluent UDF and Scheme Programming | 7 | May 17, 2018 08:26 |
Reynolds number and 1st cell height | Frank_M | Main CFD Forum | 0 | June 12, 2013 07:10 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
