October 31, 2023, 06:07 |
Overset mesh FSI OpenFOAM
Currently, I am working on an overset mesh as part of a fluid-structure interaction (FSI) simulation using preCICE to couple OpenFOAM and Calculix. The boundaries of my overset mesh are successfully deforming in sync with the moving flap. However, I am encountering issues with the movement of the interior cells in the overset mesh; they are not behaving as expected.
I am uncertain if this issue stems from the boundary conditions or potentially an error in how I have defined my dynamicMeshDict file. I have included a link to a video that demonstrates the issue I am facing: https://www.youtube.com/watch?v=vroELwhxOic. As you can see, the first cell inside the overset mesh is not behaving as it should, and I am seeking advice on how to resolve this problem. My dynamicMeshDict looks like this: Code:
FoamFile { version 2.0; format ascii; class dictionary; object dynamicMeshDict; } //dynamicFvMesh staticFvMesh; dynamicFvMesh dynamicOversetFvMesh; //solver multiSolidBodyMotionSolver; motionSolverLibs ("libfvMotionSolvers.so"); solver displacementLaplacian; displacementLaplacianCoeffs { diffusivity inverseDistance (overset1); diffusivity inverseDistance (overset); } Code:
FoamFile { version 2.0; format ascii; class pointVectorField; object pointDisplacement; } dimensions [0 1 0 0 0 0 0]; internalField uniform (0 0 0); boundaryField { overset { patchType overset; type fixedValue; } overset1 { type fixedValue; value $internalField; } walls { type uniformFixedValue; uniformValue (0 0 0); } inlet { type uniformFixedValue; uniformValue (0 0 0); } outlet { type uniformFixedValue; uniformValue (0 0 0); } lowerWall { type uniformFixedValue; uniformValue (0 0 0); } flap { type fixedValue; value $internalField; } } |
April 25, 2024, 05:40 |
xiangxiang
Rep Power: 4 |
Hi, Lundby
Have you solved this problem? I encountered the same problem when using overset grids. |
July 30, 2024, 11:05 |
Umut
Rep Power: 15 |
I'm also facing the same problem. Any update or solution? |
October 6, 2024, 15:39 |
Yes, https://www.youtube.com/watch?v=8GoG1gxc8lo
Also included contact mechanics |
October 7, 2024, 06:35 |
Umut
Rep Power: 15 |
Dear Lundby,
Thank you for sharing the video of your FSI work. I got to notice that in older OF versions (at least v2206 and older), overset boundary follows the deforming solid (deforms with it). For example in your video (Turek-Hron benchmark) the mesh around the elastic plate and its overset boundary deforms with the plate. In more recent OF versions I couldn't manage to deform the overset type boundary. Please kindly check the question I asked in this link: Front mesh boundaries (overset patch) not deforming on newer OF releases I also watched your FSI contact video (U field), I noticed there is a vibration in the whole domain in the second half of the video. I have a feeling that it is caused by dynamic mesh selections and if you visualize mesh motion it might be vibrating for no good reason. Is that the case? |
November 24, 2024, 04:12 |
#6 | |
Kangnian Wang
Thanks for your post. It looks really nice. If possible, could you please share the files of the simulation? Thanks in advance. |
fsi, openfoam. calculix, overset, precice |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 12:14 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 05:08 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
