[blockMesh] Domain selection
Old   October 18, 2023, 10:10
Default Domain selection
Filippo Pucci
filpucfd is on a distinguished road
I am generating a multi-region geometry for a conjugate heat transfer problem.
I am using the blockMeshDict to generate what will then give me the solid region, while I import as a triSurfaceMesh the two fluid domains with snappyHexMesh.
At the moment, I have the length of the solid equal to that of the fluid:
| ////////////////////////////////////////////////// solid |
| ////////////////////////////////////////////////// fluid1 |
| ////////////////////////////////////////////////// fluid2 |
| ////////////////////////////////////////////////// |solid |
However, this is not efficient, as part of the length at the beginning and towards the end of the fluid domains is intended for flow development. I would like to select only part of the solid to be kept in the mesh as a solid region, while maintaining the full bounding box and get all the fluid elements I need???
| ------------////////////////------------ solid |
I hope I was clear.
Thank you in advance for your help!
filpucfd is offline   Reply With Quote
Old   October 20, 2023, 05:29
Filippo Pucci
I have managed to get what I want using two different approaches:
1. Define three cylinder domains in blockMesh (with the central being the one I'd like to keep) and just import the fluid geometries stl in with SnappyHexMesh - although I considered it quite inefficient and I found the second method
2. Defined a simple block domain in blockMesh and then defined a cylinder (searchableCylinder) in the geometry function of SHM, along with the fluid stls.
HOWEVER, this works only with a simplified geometry.
If I try to use the same strategy with my actual geometry, it seems like that it doesn't work.
It's like one of the fluid regions absorbs the cells that I would like to assign to the cellZones.
Can anyone help? Does it depend on the refinement of the blockMesh or on the refinement levels I would assign to my SHM surfaces/features?
Or is there another reason?
This is my castellatedMesh
geometry
    unrem_fluid1_cat.stl
    	type distributedTriSurfaceMesh; //triSurfaceMesh;
    	name fluid1;
    	//scale 0.01;
    unrem_fluid2_cat.stl
    	name fluid2;
    	//scale 0.01;
    cylinder
    	type searchableCylinder;
    	point1 (0. 0. 0.);
    	point2 (0. 0. 1.);
    	radius $solRad;
// Settings for the castellatedMesh generation.
castellatedMeshControls
    // Refinement parameters
    // If local number of cells is >= maxLocalCells on any processor
    // switches from from refinement followed by balancing
    // (current method) to (weighted) balancing before refinement.
    maxLocalCells 999999999;
    // Overall cell limit (approximately). Refinement will stop immediately
    // upon reaching this number so a refinement level might not complete.
    // Note that this is the number of cells before removing the part which
    // is not 'visible' from the keepPoint. The final number of cells might
    // actually be a lot less.
    maxGlobalCells 999999999;
    // The surface refinement loop might spend lots of iterations
    // refining just a few cells. This setting will cause refinement
    // to stop if <= minimumRefine are selected for refinement. Note:
    // it will at least do one iteration (unless the number of cells
    // to refine is 0)
    minRefinementCells 5000; // 10
    // Number of buffer layers between different levels.
    // 1 means normal 2:1 refinement restriction, larger means slower
    // refinement.
    nCellsBetweenLevels 1; //2
    //interfaceRefine true;
    //maxLoadUnbalance 0;
    // Explicit feature edge refinement
    // Specifies a level for any cell intersected by its edges.
    // This is a featureEdgeMesh, read from constant/triSurface for now.
    features
            file "unrem_fluid1_cat.eMesh";    //"geom.eMesh" // .extendedFeatureEdgeMesh;
            level 0; //1
            file "unrem_fluid2_cat.eMesh";    //"geom.eMesh";
            level 0; //1
    // Surface based refinement
    // Specifies two levels for every surface. The first is the minimum level,
    // every cell intersecting a surface gets refined up to the minimum level.
    // The second level is the maximum level. Cells that 'see' multiple
    // intersections where the intersections make an
    // angle > resolveFeatureAngle get refined up to the maximum level.
    refinementSurfaces
        fluid1
            // Surface-wise min and max refinement level
            level (0 0);
            regions
            	inlet1     { level ( 0 0 ); patchInfo { type patch; } }
            	outlet1    { level ( 0 0 ); patchInfo { type patch; } }
		walls1    { level ( 0 0 ); patchInfo { type wall; } }
            faceZone fluid1;
            faceType boundary; //baffle
            cellZone fluid1;
            cellZoneInside inside;
        fluid2
            level (0 0);
            regions
            	inlet2     { level ( 0 0 ); patchInfo { type patch; } }
            	outlet2    { level ( 0 0 ); patchInfo { type patch; } }
		walls2    { level ( 0 0 ); patchInfo { type wall; } }
            faceZone fluid2;
            cellZone fluid2;
        //"(fluid1|fluid2)"
        cylinder
                level (0 0);
                cellZone solid;
                faceZone solid;
                faceType boundary;
    // Resolve sharp angles
    resolveFeatureAngle 5;
    // Region-wise refinement
    // Specifies refinement level for cells in relation to a surface. One of
    // three modes
    // - distance. 'levels' specifies per distance to the surface the
    //   wanted refinement level. The distances need to be specified in
    //   descending order.
    // - inside. 'levels' is only one entry and only the level is used. All
    //   cells inside the surface get refined up to the level. The surface
    //   needs to be closed for this to be possible.
    // - outside. Same but cells outside.
    refinementRegions
        //refinementBox
        //    mode inside;
        //    levels ((1E15 4));
    limitRegions
    	fluid1
    		mode inside;
    		levels ((0 0));
    	fluid2
    		mode inside;
    		levels ((0 0));
    // Mesh selection
    // After refinement patches get added for all refinementSurfaces and
    // all cells intersecting the surfaces get put into these patches. The
    // section reachable from the locationInMesh is kept.
    // NOTE: This point should never be on a face, always inside a cell, even
    // after refinement.
    locationInMesh (0.0001 0.0001 0.0001); // Offset from (0 0 0) to avoid
                                           //coinciding with face or edge
    locationsInMesh
        (( 0.0001 0.0001  0.0001) solid)
    // Whether any faceZones (as specified in the refinementSurfaces)
    // are only on the boundary of corresponding cellZones or also allow
    // free-standing zone faces. Not used if there are no faceZones.
    allowFreeStandingZoneFaces false;
EDIT: I solved the problem. The STL file, once remeshed, it was causing this. I am using an unremeshed version and it works.
Small domain and large domain with local scouring NTNHAN REEF3D 4 March 10, 2023 23:12
OF10 fvModels selects whole domain despite selection certain cellZone geth03 OpenFOAM Running, Solving & CFD 0 December 12, 2022 10:32
Atmospheric BCs for domain with a single boundary serving as both the inlet & outlet Newtonian OpenFOAM Running, Solving & CFD 0 July 21, 2022 15:07
[ICEM] How to generate an unstructured mesh for a 2 fluid domain rotor in ICEM CFD Hazem24 ANSYS Meshing & Geometry 0 December 21, 2020 07:52
Pressure distribution on a wall darazsbence CFX 17 October 6, 2015 11:38
