[Other] How to add water in a non-rectangular bounding box? |
October 10, 2023, 04:07 |
#21 |
Yann
Rep Power: 29 |
Thanks but it seems your link is not working. Yann |
October 10, 2023, 09:04 |
#22 |
Rhea
Rep Power: 3 |
Sorry, I don't understand why it's suddenly not working. Can you try this instead? thank you.
October 10, 2023, 09:33 |
#23 |
Yann
Rep Power: 29 |
Thanks for the upload.
OK so 2 things: 1- Your case run out of the box on my laptop with v2112 2- Your slanted wall is not defined in your blockMeshDict: only 5 out of 6 faces constituting your domain are defined in the boundary section. The missing face is automatically defined as defaultFaces with a type empty as you can see in the blockMesh log: Code:
Creating block mesh topology --> FOAM Warning : From Foam::polyMesh::polyMesh(const Foam::IOobject&, Foam::pointField&&, const cellShapeList&, const faceListList&, const wordList&, const Foam::PtrList<Foam::dictionary>&, const Foam::word&, const Foam::word&, bool) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 920 Found 1 undefined faces in mesh; adding to default patch defaultFaces I'm actually surprised the solver starts, I would have expected it to throw a fatal error complaining about a missing boundary condition for defaultFaces. Anyway, try fixing your blockMesh first and see if it solves your issue. Yann |
beach, multiphase, slope, water, waves |
Mass imbalance problem in multiphase water and steam CFX case | Antech | CFX | 1 | October 26, 2020 05:03 |
phantom region created outside blockmesh bounding box | derekm | OpenFOAM Pre-Processing | 0 | May 15, 2014 11:31 |
2D Box dropping into water | kailingkk | Fluent Multiphase | 1 | April 9, 2014 20:06 |
snapyHexMesh Bounding box | vmsandip2011 | OpenFOAM Pre-Processing | 5 | May 26, 2012 03:13 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
