[Other] Adaptive Mesh Refinement only working with certain domain size. |
September 27, 2023, 12:29 |
Hi Foamers,
I am simulating a multiphase flow consists of a single droplet simulated under different domain size condition. I would like to utilize AMR in my simulation. However, I encounter a problem whereby AMR is only working with certain domain size and not the other. Are there any strict requirement with the domain sizing or meshing strategies that I need to consider when using AMR? Here I enclosed the photo of two different domain size. One with domain width of 4-dropletDiameter (working) and the other with 8-dropletDiameter (not working) |
November 2, 2023, 05:08 |
Saeed Jamshidi
Rep Power: 8 |
Quick answer;
Please try more cells when you are increasing domain size! Best, Saeed |
amr, mesh adaptation, meshing, multiphase flow |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 14:41 |
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel | colinB | OpenFOAM Meshing & Mesh Conversion | 14 | December 12, 2018 08:07 |
killed "snappyHexMesh" | parkh32 | OpenFOAM Pre-Processing | 2 | April 8, 2012 17:12 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
