[Technical] checkMesh is ok, but checkMesh -allGeometry Failed, should I concern that? |
Dear FOAMers,
I build a case using the geometry in this link After performing blockMesh -> surfaceFeatureExtract -> snappyHexMesh, it seems the mesh is Okay ![]() Using the checkMesh along or checkMesh -allTopology to check it, everything is fine. (See the attached checkMesh-allTopology.txt) However, using checkMesh -allGeometry, failed 3 mesh checks. (See the attached checkMesh-allGeometry.txt ) Though I've asked in another thread, and @tomf told me care about only checkMesh results. I've follow that suggestion, until recently. Some of my cases, it starts fluently, and after a long while, the solution becomes slower and slower. When I extract the temperature along the centerline, there's empty value on some cells near the exit. I wonder if it's the mesh quality issue?! If I should be concerned about the quality of the mesh created, what issue should I deal with first and how to deal with it? Thank you FOAMers! ![]() Best regards, Mactone |
allgeometry, checkmesh, failed mesh checks |
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 03:35 |
Initial conditions for uniform flow | andreas | OpenFOAM | 5 | November 16, 2012 15:00 |
[OpenFOAM] ParaView/Parafoam error when making animation | Disco_Caine | ParaView | 6 | September 28, 2010 09:54 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
