[snappyHexMesh] Controlling cells near wall to ensure delta x+ and z+ < 4*y+ for LES
Old   September 5, 2023, 22:15
Default Controlling cells near wall to ensure delta x+ and z+ < 4*y+ for LES
TWB
quarkz is on a distinguished road
Hi, I'm trying to run LES simulation. In the article by Wolf dynamics on "Turbulence modeling in OpenFOAM - Theory and applications", it is stated that the recommended mesh near wall should have delta x+ and z+ < 4*y+ for LES simulation.
As shown in the diagram, the x+ ~ 10*y+. What are the key variables which I must change in snappyHexMeshDict in order to achieve it?
Can someone help?
Thanks.
quarkz is offline   Reply With Quote
Old   September 10, 2023, 03:06
M
AtoHM is on a distinguished road
Disclaimer: snappyHexMesh is not a great tool for accurate low-Re meshes. If you look around here, alot of topics are about creating good layers but most of the time, its not possible to get a good solution.
That being said, you got to estimate the yplus, e.g. with this tool https://www.cfd-online.com/Tools/yplus.php. Then in the snappyHexMeshDict in the addLayersControls you set
relativeSizes false;
expansionRatio <whatYouWish>;
firstLayerThickness <yourValue>;
minThickness <smallerThanYourValue>;
layers
    YourMeshRegion { nSurfaceLayers <nLayers>; }
Where firstLayerThickness is what the yPlusEstimator puts out. minThickness should be below, about 1 or 2 magnitudes to allow the layers growing in all regions.
Good luck!
AtoHM is offline   Reply With Quote
Old   September 10, 2023, 23:31
TWB
Hi AtoHM, thanks for the reply. I have already set the firstLayerThickness and expansionRatio. I'll check out the minThickness option.
flow over cylinder in openFoam saeed jamshidi OpenFOAM Pre-Processing 3 August 11, 2023 16:16
chtMultiRegionFoam speed up qwertz OpenFOAM Running, Solving & CFD 8 September 18, 2021 07:16
[snappyHexMesh] How to draw a 3D-Drawing for Meshing Kahnbein.Kai OpenFOAM Meshing & Mesh Conversion 4 June 15, 2021 13:16
cellZone not taking all the cells inside rahulksoni OpenFOAM 0 January 16, 2019 02:16
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
