[Salome] zero area patch created after extrudemesh
Old   August 17, 2023, 04:32
Default zero area patch created after extrudemesh
Song Young Ik
songyi719 is on a distinguished road
I created quasi-2D single cell thickness mesh using salome, and used extrudemesh to create axisymmetric 5 degree mesh
My initial goal was to create it directly from salome, but since unv format can't handle such polyhedral cells inside it, I moved created med file to gmsh and converted again using gmshtofoam, however it couldn't convert it properly since such 'could not match gmsh face' error occured.
Whatever, I exported quasi-2D mesh using unv and used ideaunvtofoam and extrudemesh, and I got wedge mesh
But after that, I got some patch that is invisible from paraview, but still contains 1000 faces which was exact # of faces which was face containing rotating axis at quasi-2D mesh.
How should I deal with this infinitesimal patch? Is it ok to just leave it alone? Or should I do something to remove it?
songyi719 is offline   Reply With Quote
extrudemesh, patch, wedge
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 03:01
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
