[snappyHexMesh] Supposedly missing 'maxNonOrtho' keyword' from SHMDict |
August 16, 2023, 13:02 |
Prom
Rep Power: 3 |
Hi everyone. I am using SHM and the following error continues to appear:
--> FOAM FATAL IO ERROR: (openfoam-2306) Entry 'maxNonOrtho' not found in dictionary "/Users/prom----/OpenFOAM/ibukunOluwa/testCases/nstxuTile/testSnappy/system/snappyHexMeshDict.meshQualityControls" file: system/snappyHexMeshDict.meshQualityControls at line 9 to 306. From bool Foam::dictionary::readEntry(const Foam::word &, T &, enum keyType:ption, IOobjectOption::readOption) const [T = double] in file /Volumes/OpenFOAM-v2306/src/OpenFOAM/lnInclude/dictionaryTemplates.C at line 327. FOAM exiting However, I do have 'maxNonOrtho' listed in the meshQualityDict subdictionary in SHM. I have no idea what the issue could be. I even restarted openFOAM but it still produced the error. I am using openFOAM v2306. SHMDict is attached – please advise on what I need to do. |
August 17, 2023, 02:48 |
M
Rep Power: 13 |
It is listed in the meshQualityControls -> relaxed subdictionary, but missing inside meshQualityControls itself. Add it there as
meshQualityControls { ... maxNonOrtho 65; ... } |
August 17, 2023, 12:50 |
Prom
Rep Power: 3 |
Thanks so much, that worked! I also realized that many keyword parameters were not defined in my meshQualityDict dictionary.
Note that I included the line #include "meshQualityDict" at the top of the meshQualityControls sub-dictionary. Keywords like maxNonOrtho should be given values in meshQualityDict and be called up on in snappyHexMesh. |
[OpenFOAM.org] RHEL 7.8 Issues installing ParaView - Third Party install not creating OpenMPI | browny | OpenFOAM Installation | 2 | April 24, 2021 06:18 |
SIGN= keyword required but missing from the license certificate | SKDinfinity | Hardware | 1 | August 30, 2016 06:54 |
what is syntax error : missing ')' before ';' | aleisia | Fluent UDF and Scheme Programming | 8 | March 10, 2015 16:42 |
[OpenFOAM] Xlib: extension "GLX" missing on display | goldbeard | ParaView | 5 | March 24, 2013 14:12 |
errors when installing openfoam2.1 on ubuntu12.o4 | hewei | OpenFOAM Installation | 5 | May 29, 2012 08:43 |
