[snappyHexMesh] Addlayer issue, added layer doesn't match the surface |
July 27, 2023, 04:33 |
Feiyi Chen
I'm a beginner of OpenFOAM and I'm stucked in addlayer right now, hope someone can tell me why the layer added doesn't match the geometry surface.
The issue layer keep good orthogonality, but it doesn't match the surface. I tried to change several sets in the addlayer control but just doesn't work. Hope someone can tell me how to set it. Thanks! |
July 27, 2023, 07:26 |
Feiyi Chen
Worked out, It is because the thickness of refinment mesh just above the surface is thinner than setted addlayer thickness... So, the addlayer process actually didn't work
[snappyHexMesh] Layering Issue!!!! Help!!!! | vava10 | OpenFOAM Meshing & Mesh Conversion | 4 | February 17, 2021 07:00 |
[snappyHexMesh] Holes in internal mesh when adding boundary layer snappyHex | otaolafr | OpenFOAM Meshing & Mesh Conversion | 3 | February 8, 2021 08:19 |
[snappyHexMesh] Help with Snappy: no layers growing | GianF | OpenFOAM Meshing & Mesh Conversion | 2 | September 23, 2020 08:26 |
[snappyHexMesh] Adding layer 3d wing (y+=1) | Dorian1504 | OpenFOAM Meshing & Mesh Conversion | 4 | November 10, 2017 00:56 |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 13:47 |
