[Other] "Seeking Help to Resolve OpenFOAM Error: Inflow Velocity Point Not Found in Mesh" |
July 23, 2023, 00:04 |
Haider
Rep Power: 3 |
Hello OpenFOAMERS,
Can anyone guide me on how to fix the following error? I tried both serial and decomposition methods (e.g. scotch, hierarchical) but the problem is not resolving, looking forward to suggestions. Thank You! Regards, Haider [8] --> FOAM FATAL ERROR: (openfoam-2012) [8] Inflow velocity point for turbine.blade3.element16 not found in mesh [8] [8] From void actuatorLineElement::calculateForce() [8] in file fvOptions/actuatorLineSource/actuatorLineElement/actuatorLineElement.C at line 468. [8] FOAM parallel run aborting |
October 2, 2023, 14:08 |
Resolved?
Jacob Fontaine
Rep Power: 4 |
I am encountering a similar issue, did you ever resolve this issue? |
October 3, 2023, 02:51 |
Haider
Rep Power: 3 |
You should change the mesh or change the number of cores. Its a debuging |
[RapidCFD] Discussion thread on how to install and use RapidCFD | newoscar | OpenFOAM Community Contributions | 88 | May 17, 2024 10:39 |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 06:29 |
[Other] Compiling hacFoam (Ubuntu 10.04)(OF2.0.0)(LAMMPS13Jul2010)) | Henrik_E | OpenFOAM Installation | 3 | September 29, 2016 17:16 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 05:26 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
