[snappyHexMesh] Ideas on how to make this mesh better? |
July 20, 2023, 14:29 |
Julio Pieri
Rep Power: 9 |
Hi all!
Any ideas on how to make this mesh look better? The line to which elements are snapping is a feature edge that splits the surface into two. I had to do this so I could later extrude the bigger surface (and make tube wall in multi-region) without conflicting the side of extruded elements with the 90deg nozzle. Note that the points along this line from both sides are not aligned, which creates poly elements. Intuitively, I'd say making them aligned would be better for the simulation Also note that this happens in the corners as well, and that happens a lot with me. Any suggestions on ways to remedy this? Is this "misalignment" a problem at all? Thanks!! |
July 27, 2023, 11:02 |
Julio Pieri
Rep Power: 9 |
Sorry to up this, but any ideas?
featureedges, misalignment, snappy |
Two phase flow in porous medium | Milaad | OpenFOAM | 7 | July 1, 2024 06:08 |
[snappyHexMesh] Mesh quality ideas needed | Vignesh2508 | OpenFOAM Meshing & Mesh Conversion | 7 | December 7, 2017 10:45 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 09:48 |
[ICEM] How to make Pereodic Tetra mesh? | ale-kc | ANSYS Meshing & Geometry | 6 | November 15, 2010 15:23 |
