[blockMesh] BlockMesh - Challenging my first puzzle: 1 x 0 for it... |
July 11, 2023, 06:23 |
Raphael
Hey guys
I need help to solve the following problem according to the diagram of the attached image. Could you help me solve this exercise so that I can better understand where I'm going wrong? Thank you in advance ____________________________________ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // scale 0.1; vertices ( (0 0 0) (10 0 0) (10 4 0) (0 4 0) (12 4 0) (12 2 0) (14 0 0) (24 0 0) (24 4 0) (14 4 0) (0 0 1) (10 0 1) (10 4 1) (0 4 1) (12 4 1) (12 2 1) (14 0 1) (24 0 1) (24 4 1) (14 4 1) ); blocks ( hex (0 1 2 3 10 11 12 13) (20 20 20) simpleGrading (1 1 1) hex (1 5 4 2 11 15 14 12) (20 20 20) simpleGrading (1 1 1) hex (5 6 9 4 15 16 19 14) (20 20 20) simpleGrading (1 1 1) hex (6 7 8 9 16 17 18 19) (20 20 20) simpleGrading (1 1 1) ); edges ( arc 1 5 (10.585786 1.414214 0) arc 11 15 (10.585786 1.414214 1) arc 5 6 (13.414214 1.414214 0) arc 15 16 (13.414214 1.414214 1) ); boundary ( movingWall { type wall; faces ( (3 13 12 2) (2 12 14 4) (4 14 19 9) (9 19 18 8) ); } fixedWalls { type wall; faces ( (0 10 13 3) (0 1 11 10) (1 5 15 11) (5 6 16 15) (6 7 17 16) (7 8 18 17) ); } frontAndBack { type empty; faces ( (0 3 2 1) (10 11 12 13) (1 2 4 5) (11 15 14 12) (2 4 9 6) (15 16 19 14) (6 9 8 7) (16 17 18 19) ); } ); ____________________________________ Result... .. --> FOAM FATAL ERROR: (openfoam-2306) face 4 in patch 2 vertices 4((10 4 0) (12 4 0) (14 4 0) (14 0 0)) does not have neighbour cell face: 4(2 4 9 6) From Foam::labelList Foam:olyMesh::facePatchFaceCells(const faceList&, const labelListList&, const faceListList&, Foam::label) const in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 119. FOAM aborting [stack trace] ============= #1 Foam::error::simpleExit(int, bool) in ~/OpenFOAM/OpenFOAM-v2306/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so #2 Foam:olyMesh::facePatchFaceCells(Foam::List<Foam ::face> const&, Foam::List<Foam::List<int> > const&, Foam::List<Foam::List<Foam::face> > const&, int) const in ~/OpenFOAM/OpenFOAM-v2306/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so #3 Foam:olyMesh::setTopology(Foam::List<Foam::cellS hape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::List<int>&, Foam::List<int>&, int&, int&, Foam::List<Foam::cell>&) in ~/OpenFOAM/OpenFOAM-v2306/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so #4 Foam:olyMesh:olyMesh(Foam::IOobject const&, Foam::Field<Foam::Vector<double> >&&, Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::PtrList<Foam::dictionary> const&, Foam::word const&, Foam::word const&, bool) in ~/OpenFOAM/OpenFOAM-v2306/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so #5 Foam::blockMesh::createTopology(Foam::IOdictionary const&, Foam::word const&) in ~/OpenFOAM/OpenFOAM-v2306/platforms/linux64GccDPInt32Opt/lib/libblockMesh.so #6 Foam::blockMesh::blockMesh(Foam::IOdictionary const&, Foam::word const&, Foam::blockMesh::mergeStrategy, int) in ~/OpenFOAM/OpenFOAM-v2306/platforms/linux64GccDPInt32Opt/lib/libblockMesh.so #7 ? in ~/OpenFOAM/OpenFOAM-v2306/platforms/linux64GccDPInt32Opt/bin/blockMesh #8 ? in /lib/x86_64-linux-gnu/libc.so.6 #9 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #10 ? in ~/OpenFOAM/OpenFOAM-v2306/platforms/linux64GccDPInt32Opt/bin/blockMesh ============= Abortado (imagem do núcleo gravada) |
Problem with blockMesh | yoshiyagi | OpenFOAM Pre-Processing | 2 | November 7, 2022 06:49 |
[blockMesh] Problem with running blockMesh | yoshiyagi | OpenFOAM Meshing & Mesh Conversion | 3 | November 3, 2022 00:49 |
[blockMesh] OpenFOAM blockMesh bus error | BRH | OpenFOAM Meshing & Mesh Conversion | 0 | April 12, 2021 12:02 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 15:53 |
[blockMesh] set of xyz data in blockMesh | psk | OpenFOAM Meshing & Mesh Conversion | 12 | August 27, 2013 09:37 |
