[Other] Checkmesh core dumped even with suff RAM |
Song Young Ik
Rep Power: 4 ![]() |
Yep. snappyhexmesh do work fine, but problem here is checkmesh
After I reload my cloud system, even with very sufficient ram, 'core dumped' error occurs while doing checkmesh, and while running simplefoam stage, such error code is shown Code:
[90] #0 Selecting patchDistMethod meshWaveFoam::error::printStack(Foam::Ostream&) at ??:? [90] #1 Foam::sigFpe::sigHandler(int) at ??:? [90] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [90] #3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:? [90] #4 Foam::operator/(double const&, Foam::tmp<Foam::Field<double> > const&) at ??:? [90] #0 Selecting patchDistMethod meshWaveFoam::error::printStack(Foam::Ostream&) at ??:? [90] #1 Foam::sigFpe::sigHandler(int) at ??:? [90] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [90] #3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:? [90] #4 Foam::operator/(double const&, Foam::tmp<Foam::Field<double> > const&) at ??:? [90] #5 Foam::surfaceInterpolation::makeDeltaCoeffs() const at ??:? [90] #0 Selecting patchDistMethod meshWaveFoam::error::printStack(Foam::Ostream&) at ??:? [90] #1 Foam::sigFpe::sigHandler(int) at ??:? [90] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [90] #3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:? [90] #4 Foam::operator/(double const&, Foam::tmp<Foam::Field<double> > const&) at ??:? [90] #5 Foam::surfaceInterpolation::makeDeltaCoeffs() const at ??:? [90] #6 Foam::surfaceInterpolation::deltaCoeffs() const at ??:? [90] #7 Foam::RASModel<Foam::incompressibleMomentumTransportModel>::RASModel(Foam::word const&, Foam::geometricOneField const&, Foam::geometricOneField const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::viscosity const&) at ??:? So I just removed checkmesh stage, but it showed same error. Snappyhexmesh is definitely working fine with no mesh with non-orthogonality, but it seems there is some error to mesh. What would be reason of core dump, and how can I fix my mesh? 영어 한국어 일본어 중국어 (간체) 중국어 (번체) 베트남어 인도네시아어 태국어 독일어 러시아어 스페인어 이탈리아어 프강스어 복사하기 이 확장을 지원합니다 영어 한국어 일본어 중국어 (간체) 중국어 (번체) 베트남어 인도네시아어 태국어 독일어 러시아어 스페인어 이탈리아어 프강스어 복사하기 이 확장을 지원합니다 Last edited by songyi719; July 8, 2023 at 23:03. Reason: Wrong error code paste |
checkmesh, core dumped, surfaceinterpolation |
buoyantBoussinesqSimpleFoam: Floating point exception (core dumped) | raghav.venky | OpenFOAM Running, Solving & CFD | 11 | June 30, 2019 13:33 |
M.2 SSD as substitude for RAM...optimum core number | fonograph | Hardware | 1 | January 14, 2018 05:26 |
[foam-extend.org] core dumped for foam extended 3.2 on Ubuntu 16.04 | qjh888 | OpenFOAM Installation | 9 | September 27, 2016 16:39 |
solving a conduction problem in FLUENT using UDF | Avin2407 | Fluent UDF and Scheme Programming | 1 | March 13, 2015 02:02 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
