[mesh manipulation] Can't create new cellSet using setSet
Old   July 6, 2023, 08:56
Unhappy Can't create new cellSet using setSet
AMR96 is on a distinguished road
I have imported a mesh from Fluent and there is a problem with the unused points which results in a failed checkMesh. I want to remove these points using the setSet feature. However as I understand I have to find the cells containing these points and then remove them.
My problem is when I try to create a new cellSet to add the unwanted cells containing these points I get the following error. I searched on the forum and couldn't find anything like this.
Can someone please help me with this?
readline>cellSet p1 new
    Set:p1  Size:0  Action:new
Bad token - could not get word
AMR96 is offline   Reply With Quote
fluent mesher, mesh 3d, mesh manipulation
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
[OpenFOAM] Create cellSet from paraFoam hcl734 ParaView 0 November 20, 2015 05:09
.setSet problems Grimoli OpenFOAM 9 July 31, 2013 14:24
[mesh manipulation] how to create CellZones or cellSet from mesh didamiamia OpenFOAM Meshing & Mesh Conversion 0 July 11, 2013 12:28
Actuator disk model audrich FLUENT 0 September 21, 2009 08:06
