[Other] extrudeToRegionMesh extrude direction?
Old   June 27, 2023, 14:59
Question extrudeToRegionMesh extrude direction?
Peter Bevington
pbevington is on a distinguished road
For a multi-region case, I'm trying to extrude a box out of the bottom surface of my domain, but the extrusion always occurs in the -y direction (out of the domain), while I want the extrusion to go in the +y direction, into the domain.
My general workflow is as follows:
1) Create domain with blockmesh
2) snappyHexMesh for region specific refinement
3) topoSet to create faceZoneSet for extrusion
4) extrudeToRegionMesh
I've tried using flipMap and playing around with the surface normals, but I'm not having any success. Is there a reliable way to flip the direction of extrusion?
I've attached the case file below if you want to take a look. Thanks!
pbevington is offline   Reply With Quote
FLUENT + porous media and direction angle zog FLUENT 2 August 11, 2019 10:47
[DesignModeler] Extrude in the radial direction bongbang ANSYS Meshing & Geometry 1 September 12, 2018 17:56
[DesignModeler] DesignModeler Scripting: Direction vector in extrude command Tobias_H ANSYS Meshing & Geometry 3 July 27, 2015 19:36
[Gmsh] Cannot get the right mesh from gmsh JinBiao OpenFOAM Meshing & Mesh Conversion 2 August 31, 2010 05:51
[ICEM] Changing edge direction la7low ANSYS Meshing & Geometry 2 June 7, 2010 14:26
