[snappyHexMesh] Internal flow using stl file with snappyHexMesh
Old   June 23, 2023, 09:18
Default Internal flow using stl file with snappyHexMesh
Björn
Björnpork is on a distinguished road
Hi everyone
I have a stl file of a swirl separator. I want to simulate the inner flow in OpenFoam. I’m very sure that I have to use snappyHexMesh and therefore I need a “box” in which the model placed. But for some reason whenever I run simulation or just want to have a look at the model in paraview I only see the box without the model. What am I missing?
I have the stp file of the swirl separator from here:
https://grabcad.com/library/zyklonabscheider-1
Following are the files snappyHexMeshDict and blockMeshDict.
snappyHexMeshDict:
| \\ / O peration | Version: 10 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
format ascii;
class dictionary;
object autoHexMeshDict;
castellatedMesh true;
snap true;
addLayers true;
geometry
Cyclone-Mesh_230622_GSI.stl
type triSurfaceMesh;
name cyclone;
castellatedMeshControls
maxLocalCells 8000000;
maxGlobalCells 10000000;
minRefinementCells 0;
maxLoadUnbalance 0.0;
nCellsBetweenLevels 1;
features
file "ImageToStl.com_zyklonabscheider-3-38.eMesh";
level 3;
refinementSurfaces
cyclone
level (3 3);
faceZone insideFaces;
cellZone insideZone;
cellZoneInside insidePoint;
insidePoint (0.0 0.0 0.0);
inlet_block
level ( 0 0 );
patchInfo
type patch;//wall;
outlet_block
level ( 0 0 );
patchInfo
type patch;//wall;
walls_block
level ( 0 0 );
patchInfo
type patch;//wall;
resolveFeatureAngle 30;
refinementRegions
locationInMesh (0 0 0);
allowFreeStandingZoneFaces false;
snapControls
nSmoothPatch 5;
tolerance 1.0;
nSolveIter 300;
nRelaxIter 10;
nFeatureSnapIter 5;
implicitFeatureSnap false;
explicitFeatureSnap true;
multiRegionFeatureSnap false;
addLayersControls
relativeSizes false;
layers
insideZone_to_outsideZone
nSurfaceLayers 3;
expansionRatio 1.005;
finalLayerThickness 0.0001;
minThickness 0.00005;
nGrow 0;
featureAngle 85;
slipFeatureAngle 25;
nRelaxIter 5;
nSmoothSurfaceNormals 4;
nSmoothNormals 3;
nSmoothThickness 10;
maxFaceThicknessRatio 0.5;
maxThicknessToMedialRatio 0.2;
minMedianAxisAngle 90;
nBufferCellsNoExtrude 0;
nLayerIter 50;
meshQualityControls
maxNonOrtho 65.0;
maxBoundarySkewness 20.0;
maxInternalSkewness 4.0;
maxConcave 80.0;
minVol 1.0E-14;
minTetQuality 1.0E-20;
minArea -1.0;
minTwist 0.02;
minTriangleTwist -1.0;
minDeterminant 0.01;
minFaceWeight 0.05;
minVolRatio 0.01;
minVolCollapseRatio 0.1;
nSmoothScale 4;
errorReduction 0.75;
relaxed
maxNonOrtho 75.0;
writeFlags
scalarLevels
layerSets
layerFields
mergeTolerance 1e-6;
blockMeshDict:
FoamFile
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1; //This gives you the scale: 0.001 would mean all units in this file are [mm]
vertices //list of vertices defining the geometry
(-1000 -1000 -1000) //This is point 0. Not 1!
(1000 -1000 -1000) //This is point 1
(1000 1000 -1000) //point 2
(-1000 1000 -1000) //point 3
(-1000 -1000 1000) //point 4
(1000 -1000 1000) //point 5
(1000 1000 1000) //point 6
(-1000 1000 1000) //point 7
blocks //defining the block which the geometry is made out of
hex (0 1 2 3 4 5 6 7) (50 25 50) simpleGrading (1 1 1)
//this means that the only block in the geometry is defined by vertices (0 1 2 ...), there are 100, 10
//and 1 cells in the x, y, and z direction and that in each direction all the cells have the same length
//edges
// spline 0 1
// (5 -2 0)
// spline 4 5
// (5 -2 0.1)
boundary (
inlet_block
type patch;
faces (
(3 7 4 0)
outlet_block
type patch;
faces (
(2 1 5 6)
walls_block
type wall;
faces (
(1 2 3 0)
(7 6 5 4)
(0 4 5 1)
(2 6 7 3)
Björnpork is offline   Reply With Quote
Old   July 6, 2023, 00:43
FOAMraj
BIRAJ is on a distinguished road
Make sure to check the scale factor in blockMesh and the location in mesh in snappyHexMeshDict.
BIRAJ is offline   Reply With Quote
mesh, openfoam, snappyhexmesh, stl
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 04:50
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 06:18
