June 20, 2023, 10:13 |
Non-matching meshes on mesh parts
Giorgio
Rep Power: 3 |
Dear all, I am modeling a network of pipes connected with T elements.
I generated a partion of the geometry where I divided the Ts from the straight pipes, in order to use an unstructured mesh on Ts and structured on pipes. The whole geometry must have a boundary layer on the walls also. I generated the mesh starting with a Netgen 3D on a T, propagated on the pipes using 3D extrusion, and again Net3D on the following Ts. The mesh generation seems fine. However, when I export the mesh (I use salomeToOpenFOAM.py) the export fails with "IndexError: list assignment index out of range" and some defaultPatches are generated. Those default patches are places at the pipe/T junctions where the T mesh is generated AFTER the pipe mesh. Is there a way to avoid this? Unfortunately I cannot generate all the T meshes before because of pipes connecting different Ts which would imply having extrusion constrained at both ends. Thanks in advance! |
June 20, 2023, 10:18 |
Giorgio
Rep Power: 3 |
Sorry I posted it twice, please use the other post...
default patches, hybrid meshes, non-matching meshes |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
[ICEM] Bad Quality Hybrid Mesh External Flow | tim13 | ANSYS Meshing & Geometry | 0 | March 8, 2020 03:22 |
Mesh Independance Test VS Matching CFD Results with Experiments | fadoobaba | FloEFD, FloWorks & FloTHERM | 5 | May 10, 2018 09:49 |
[ANSYS Meshing] Assigning different mesh densities for different parts in ANSYS ICEMCFD Tetra Mesher | johnnydrama7 | ANSYS Meshing & Geometry | 0 | September 19, 2016 14:10 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
