June 1, 2023, 11:55 |
Coarse mesh
Rep Power: 3 |
Hi there,
This is Julio. I am new to OpenFoam and CFD. I have a very basic question but I am having a hard time trying to fix it. I have a very basic space I want to analyze the temperature and air speed variations within. I have inlet boundaries and some other interior features. The problem occurs when generating the main boundary of the space the shape is similar to a semicircle but I simplified it with straight lines. However, when I run the OpenFOAM meshing it generates a mesh with very coarse edges and this gives me very strange results. I have marked in red how I think it should be to obtain more realistic results. Does anybody know why is this happening? which parameters should I modify to obtain a straight mesh? which is the right settings so all the inlets work as they should? which is the right boundary type for a AC system, inlet boundary or inlet flow-rate boundary? Thanks in advance. |
June 19, 2023, 10:10 |
Vinzenz Götz
Rep Power: 5 |
Hello Julio,
please upload a picture of your mesh and post your sHMDict. Why do you use straight lines and not just a semicircle? Where are your inlets and where are your outlets? What solver are you using? What boundary conditions are you using right now? Best regards, Vinz |
hvac, snappy hex mesh |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 05:17 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 12:14 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
