[snappyHexMesh] Multi-region meshing produces too many regions
Old   May 17, 2023, 06:13
Default Multi-region meshing produces too many regions
Fotis Anagnostopoulos
efalpha is on a distinguished road
Dear all,
I am trying to simulate a multi-physics flow. In particular, I have a high temperature flow through a pipe surrounded by ambient air. Similarly to "snappyHeatExchanger" example, I create different .stl files for each surface.
The problem is that, after the meshing with snappy, splitMesh do not result the proper regions, i.e. 'env', 'solid' and 'pipe_flow' but instead I get up to 2k new regions. Moreover, the reconstructed pipe surface is coarse and with HOLES (pls see figures).
I tried so far to play with the following increasing initial blockMesh resolution, increasing refinement level, using implicitFeatureSnap, subdivide the .stl's for more dense surface, using admesh to correct the stls, etc. The problem persists.
Please help, I have run out of ideas and the deadline is coming fast. Ι include the "snappyHexMeshDict" here, along with some images, while the full case dir (along with VTK files after snappyHex) can be found at: https://mega.nz/folder/xE0XGAYQ#I2I_DTAlujoTq4YW1mDNbA
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
#includeEtc "caseDicts/mesh/generation/snappyHexMeshDict.cfg"
castellatedMesh on;
snap            on;
addLayers       off;
geometry
    pipe_flow
        type            triSurfaceMesh;
        file            "pipe_flow.stl";
        regions
            inlet           { name inlet; }
            outlet           { name outlet; }
    env
        file            "env.stl";
        regions
            walls           { name walls; }
    solid
        file            "solid.stl";
        regions
            onOutlet        { name onOutlet; }
            OnInlet        { name OnInlet; }
    pipe_to_solid
        file            "pipe_to_solid.stl";
    env_to_solid
        file            "env_to_solid.stl";
castellatedMeshControls
// Settings for the castellatedMesh generation.
    // Refinement parameters
    maxLocalCells 10000000;   //max cells per CPU core
    maxGlobalCells 20000000; //max cells to use before mesh deletion step
    minRefinementCells 10;  //was 0 - zero means no bad cells are allowed during refinement stages
    maxLoadUnbalance 0.10;
    nCellsBetweenLevels 2; // expansion factor between each high & low refinement zone
    features
        file "pipe_to_solid.eMesh"; // file containing edge mesh
        level 2;               // level of refinement
        file "env_to_solid.eMesh"; // file containing edge mesh
    // Surface based refinement
    refinementSurfaces
        env
            level           (1 2);
            regions
                inlet           { level (1 2); patchInfo { type patch; } }
                outlet           { level (1 2); patchInfo { type patch; } }
                walls           { level (1 2); patchInfo { type wall; } }
        pipe_flow
            level           (1 2);
            regions
        solid
            level           (1 2);
            regions
                onOutlet        {level (1 2); patchInfo { type patch; } }
                onInlet        {level (1 2); patchInfo { type patch; } }
        pipe_to_solid
            level           (1 2);
            faceZone        pipe_to_solid;
            cellZone        pipe_flow;
            cellZoneInside  outside;
        env_to_solid
            level           (1 2);
            faceZone        env_to_solid;
            cellZone        env;
    refinementRegions
      locationInMesh (0.00 0.008 0.015);
  // locationInMesh (-0.0025 0.001 0.002);
   // locationInMesh (-0.025 0.00 0.05); // TUBE
   // locationOutMesh (0.0040 0.008 0.015);
    //resolveFeatureAngle 45;
    // resolveFeatureAngle 45;
    resolveFeatureAngle 60;
    featureAngle 30;
snapControls
    // implicitFeatureSnap    true;
    nSmoothPatch 20;
    tolerance 10;
    nSolveIter 300;//25;
    nRelaxIter 10;
    nFeatureSnapIter 25;
    explicitFeatureSnap false;
    multiRegionFeatureSnap false;
addLayersControls
    layers
        walls
            nSurfaceLayers 2;
            mergeFaces true;
        pipe_to_solid
            nSurfaceLayers 2;
            mergeFaces true;
        env_to_solid
            nSurfaceLayers 2;
            mergeFaces true;
    relativeSizes       true;
    expansionRatio      1.2;
    finalLayerThickness 0.1;
    minThickness        1e-4;
writePrecision 6;
mergeTolerance 1e-5;
Thank you all in advance for your help.
efalpha is offline   Reply With Quote
Old   June 6, 2023, 04:23
I found that the problem is in the geometry: the .stl files are not meshed properly.
The question that could be asked now is with regard to the proper way to make .stl meshes. I will put the question in a new thread.
[snappyHexMesh] Multi region spliting doesn't result in desired boundaries Hr_kules OpenFOAM Meshing & Mesh Conversion 1 July 20, 2022 09:33
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 06:07
[snappyHexMesh] Multi region meshing with SHM creates extra regions Dav3dum OpenFOAM Meshing & Mesh Conversion 0 August 8, 2016 09:54
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 15:07
decomposePar -region (OF 2.1) without splitting regions in separate parts michielm OpenFOAM Pre-Processing 1 November 15, 2013 06:07
