April 10, 2023, 12:30 |
Bad layer formation
Rafael
Does anyone know what is the likely reason that is causing those wrong layers in my mesh?
layers.jpg bFuga.jpg |
April 11, 2023, 04:58 |
M
Rep Power: 13 |
Hello Rafael,
What you see in picture one appears to be a graphical issue of the crincle option in Paraview. The second image shows collapsing layers around an edge, which is a common problem in layer generation with snappyHexMesh. There are several forum posts here about such problems and there is not a singular answer that will help you right away. Best would be to use the search tool and cross reading some threads. Here are a few things that help me from time to time: use relative instead of absolute layer thickness definition, increase addLayersControls>featureAngle or try the DisplacementMotionSolver mesh shrinker: https://www.openfoam.com/documentati...ntmotionsolver This is only available in the ESI version of OpenFOAM and, as shown, not a definitive solution to the problem. These are some glues, I hope it helps! Good luck. |
airfoil, layer, snap |
Boundary Layer Mesh must cover the whole thickness of BL | sasanghomi | CFX | 2 | June 11, 2019 22:16 |
[snappyHexMesh] Bad meshing result on corrugated metal sheet | UebertreibeR | OpenFOAM Meshing & Mesh Conversion | 1 | August 19, 2016 05:55 |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 13:41 |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 14:47 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 15, 2003 00:19 |
