[Salome] Meshing strategy in SALOME
Old   March 30, 2023, 11:31
Default Meshing strategy in SALOME
Giorgio
giorgianig is on a distinguished road
Does anyone have any tip to generate large meshes (~50M elements) in SALOME?
I am trying to mesh a filtering grid with tetra elements and viscous layers, to be used in OpenFoam (pisoFoam). The mesh take ages to be computed and most of the time the quality is too low to be used. I have already splitted the geometry in 3 volumes, one containing the grid and the others for the inlet and outlet. I use NetGen for the mesh of the volume containing the grid, with viscous layers, and extrusion for the rest. The meshing of the grid volume is the one giving problems.
I am quite new to Salome, I am wondering if there is a procedure to obtain large quality meshes (for example, mesh the 2d wall first, then computing the 3d mesh maybe?, decreasing the size little by little?)
Thanks in advance.
ps. I wanted to put a picture of the grid but I am not sure how to do it....
giorgianig is offline   Reply With Quote
Old   September 14, 2023, 07:07
Klaus
klausb will become famous soon enough
Did you try Gmsh within Salome?
Have a look at page 40 in this presentation https://gmsh.info/doc/course/general_overview.pdf . It seems to be very fast when it comes to generating large meshes.
I am also looking into Salome in the context of large meshes including boundary layers at the moment.
klausb is offline   Reply With Quote
Old   September 14, 2023, 10:14
Alczem is on a distinguished road
Hey!
Have you tried cfMesh? It is relatively fast and handle boundary layers and complex geometries quite well in my experience. If you have a single fluid region and no baffles, I would give it a try
Alczem is offline   Reply With Quote
meshing time, strategy, tetra meshing, viscous layer
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points Simurgh OpenFOAM Meshing & Mesh Conversion 4 August 25, 2023 08:58
[ANSYS Meshing] Meshing strategy for a heat sink with fins in a conjugated heat transfer problem mariashva ANSYS Meshing & Geometry 0 January 25, 2018 03:41
[ICEM] 3D Meshing strategy : a bay Magicano ANSYS Meshing & Geometry 0 January 3, 2013 20:02
3d meshing strategy for propeller in gambit Harikrishna FLUENT 3 January 12, 2012 07:38
block meshing strategy J Reed Siemens 0 March 7, 2000 12:41
