[snappyHexMesh] meshing very narrow cylindrical bars(20 micron diameters)
Old   March 21, 2023, 18:07
Default meshing very narrow cylindrical bars(20 micron diameters)
Farzad Faraji
farzadmech is on a distinguished road
Hello all
I am doing snappyHexMesh on a very small object (20 micron diameters on a cylindrical pattern), but I git wrong faces. Please see the figure 1,2,3,4 which I attach. I already have done cylindrical refinement around the object, but I still got bad faces. Is there any suggestion what can I do to mesh this object better?
Thanks,
Farzad
farzadmech is offline   Reply With Quote
Old   March 21, 2023, 22:40
Default Solution suggested in Forums
Farzad Faraji
I came across these two threads which might be helpful. Basically they are saying use one block for upstream and another for downstream and
mergeMeshes "../run/blabla1" rotor "../run/blabla2" stator
to merge both blocks(first block with snappyHexMesh) together.
blockMesh - two blocks with different vertices
How to use mergeMeshes ?? Examples?
I am going to test this approach, but any suggestion is highly appreciated.
Thanks,
Farzad
Old   March 25, 2023, 02:11
Farzad Faraji
It will be easier to rescale the whole problem by several orders(1e6) and then use the snappyHexMesh to mesh the whole thing and then rescale it back to the original scale using
transformPoints -scale '(0.000001 0.000001 0.000001)'
Also, since meshing process will be very time consuming, it is better to use snappyHexMesh in parallel;
How to run snappyHexMesh in parallel:
- decomposeMethod in decomposeParDict must be hierarchical or scotch !
- run "decomposePar"
- run "mpirun -np 8 -parallel snappyHexMesh -overwrite"
- afterwards run "reconstructParMesh -mergeTol 1e-06 -latestTime"
Thanks,
Farzad
Thanks,
Farzad
openfoam, snapphexmesh, wrong faces
[ANSYS Meshing] Meshing of a 3d Ringwing in a cylindrical enclosure Lukas_ZH ANSYS Meshing & Geometry 5 March 14, 2015 06:49
Meshing a quasi-2D cylindrical wedge evcelica CFX 2 January 10, 2013 09:51
[ICEM] Problem Meshing a Cylindrical sector in ICEM SRead ANSYS Meshing & Geometry 4 July 18, 2012 15:10
Meshing a cylindrical volume pranab_jha ANSYS Meshing & Geometry 13 March 24, 2010 09:17
meshing tips for a rotating cylindrical jar.... Jaswi CFX 0 May 16, 2007 06:39
