[blockMesh] Inward-facing faces error
Old   March 2, 2023, 05:41
Default Inward-facing faces error
MAK
COSMICBUDDHA is on a distinguished road
Hello, i am making an axisymmetric sector of pipe . For visualising attaching image.
I have generated the blockMesh file as follows:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  10
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
	(0 0 0)
	(0 0.00499524 0.000218097)
	(0 0.00499524 -0.000218097)
	(1.36 0 0)
	(1.36 0.00499524 0.000218097)
	(1.36 0.00499524 -0.000218097)
blocks
    hex (0 3 4 1 0 3 5 2) (200 50 1) simpleGrading (1 0.2 1)
edges
   arc 1 2 (0 0.005 0)
   arc 5 4 (1.36 0.005 0)
boundary
	inlet
		type patch
		faces
			(0 1 2 0)
	oulet
		type patch
		faces
			(3 5 4 3)
	surface
		type wall
		faces
			(2 1 4 5)
	axis
		type symmetry
		faces
			(0 3 3 0)
	front
		type wedge
		faces
			(4 1 0 3)
	back
		type wedge
		faces
			(3 0 5 2)
mergePatchPairs
I have tried altering the orders, various combination and even different types of hexahedral blocks but I can't seem to get it right. Can you take a look at it and help me with what's wrong? I have been on this for 3 days now.
Here's the error:
Create time
Reading "blockMeshDict"
Creating block mesh from
    "system/blockMeshDict"
Creating block edges
No non-planar block faces defined
Creating topology blocks
--> FOAM FATAL IO ERROR:
Block hex (0 3 4 1 0 3 5 2) (200 50 1) simpleGrading (1(1) 1(0.2) 1(1)) has inward-pointing faces
    4(0 0 2 1) 4(3 4 5 3) 4(1 2 5 4) 4(0 1 4 3) 4(0 3 5 2)
file: /home/cb/OpenFOAM/cb-10/run/pipeFlow/system/blockMeshDict/blocks at line 28.
    From function void Foam::blockDescriptor::check(const Foam::Istream&)
    in file blockDescriptor/blockDescriptor.C at line 106.
FOAM exiting
COSMICBUDDHA is offline   Reply With Quote
Old   March 6, 2023, 01:02
Default Update: Tried Different BlockMesh
MAK
     \/     M anipulation  |
FoamFile
    format      ascii;
    class       dictionary;
convertToMeters 1;
vertices
	(0.000000 0.000000 0.000000)
	(0.000131 0.004998 0.000000)
	(-0.000131 0.004998 0.000000)
	(0.000000 0.000000 1.360000)
	(0.000131 0.004998 1.360000)
	(-0.000131 0.004998 1.360000)
blocks
	hex (0 0 1 2 3 3 4 5) (1 50 200) simpleGrading (1 0.5 1)
edges
	arc 1 2(0.000000 0.005000 0.000000)
	arc 4 5(1.360000 0.005000 0.000000)
boundary
	inlet
		type patch;
		faces
			(0 0 2 1)
	outlet
		type patch;
		faces
			(3 4 5 3)
	axis
		type empty;
		faces
			 (0 3 3 0)
	pipewall
		type wall;
		faces
			 (4 1 2 5)
	front
		type wedge;
		faces
			(0 1 4 3)
	back
		type wedge;
		faces
			(3 5 2 0)
mergePatchPairs
This one seems to work, but I have no idea why this one does and older one doesn't. Any insight on this would be really helpful.
axisymmetric, pipe flow
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 10:23
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 06:29
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
