[blockMesh] Cannot convert Ansys .msh to OpenFoam
Old   February 25, 2023, 17:01
Exclamation Cannot convert Ansys .msh to OpenFoam
Aarib Irfan
Aarib is on a distinguished road
I have created a 3D .msh file in Ansys and I'm trying to convert it into openfoam but it says file not found. File is in the same directory as you can see but it's still giving the same error.
aarib12@DESKTOP-1HJ559V:~/OpenFoam/test/backwardFacingStep2D$ ls
0  Allclean  Allrun  README  constant  mesh.msh  system  test.msh
aarib12@DESKTOP-1HJ559V:~/OpenFoam/test/backwardFacingStep2D$ fluent3DMeshToFoam test.msh
|  \\    /   O peration     | Version:  v2012                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
Build  : _7bdb509494-20201222 OPENFOAM=2012
Arch   : "LSB;label=32;scalar=64"
Exec   : fluent3DMeshToFoam test.msh
Date   : Feb 26 2023
Time   : 01:58:32
Host   : DESKTOP-1HJ559V
PID    : 1007
I/O    : uncollated
Case   : /home/aarib12/OpenFoam/test/backwardFacingStep2D
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
--> FOAM FATAL ERROR: (openfoam-2012)
: file "test.msh" not found
    From int main(int, char**)
    in file fluent3DMeshToFoam.L at line 843.
FOAM exiting
Aarib is offline   Reply With Quote
mesh conversion
Ansys Installation on Docker Container mohsen.shiea ANSYS 11 March 14, 2024 12:18
[Other] Is it possible to convert 6Sigma file to OpenFoam Gebin Edwin George OpenFOAM Meshing & Mesh Conversion 2 April 5, 2018 06:26
OpenFoam to Ansys Ursmooth Visualization & Post-Processing 0 September 25, 2017 14:53
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
